Question about Panasonic PT-LB60U Multimedia Projector
Projector powers up then turns itself off after a few seconds
The projector turns on, the power light changes from red to green. The image is displayed. The fan starts then turns off. The power light changes from green to red then the projector turns itself off after a few seconds. The power light stays red and the projector is unresponsive.
SOURCE: Panasonic AE900U Projector
If you cant hear the fan running it isnt. While this unit has a quiet fan believe me you will know if its running during normal operation if you listen for it. This would explain your constant shutdownds.
Posted on Nov 01, 2007
SOURCE: Problem with Power up on PTD3500
Position reference device has probably fallen off the filter wheel, replace the filter wheel.
Posted on Dec 07, 2007
Motobias
  • 6 Answers
SOURCE: Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Posted on May 04, 2009
SOURCE: No image, lamp light blincking red
I have a 3 yr old AE900U dont know exact hours but prob at least 2000 hrs. about every other start up, the projector would flash little box; (replace lamp now). now a month later lamp wont come on. So this is prob the normal way a lamp will die. anything else might be another problem.
Posted on Jul 05, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Posted on Jul 07, 2009
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
Mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Mar 14, 2008 | Mitsubishi HC3000U Multimedia Projector
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_693301a25d57d47d
Sep 03, 2014 | Mitsubishi XD221U New
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Open Questions:
106 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
