Question about RCA P52960 52" Rear Projection Television
RCA P52960 Problem (bowed picture)
Hi Dan,
My name is Ben Catchings I have this TV, the RCA P52960 52" projection TV and I have the bowed picture problem. I've pulled the chasis and cleaned things up and but I'm not knowledgeable enough to figure out what the problem is exactly. If I knew what needed to be replaced I feel that I could solve the problem. Is there some advice or direction you could give me in regard to this problem?
I would greatly appreciate any assistance you may be able to share with me. Feel free to get in touch with me in any way you'd like. I'll leave my information below.
Thank you for your time,
Benjamin Catchings
e. bcatchings@gmail.com
c. 225.284.6651
  • 2 more comments
  • skello27 Feb 04, 2009
    my pic bowed up and wide its very zoom out
    my pic is very zoom out
    can some one help me on this problem my rca P52960 has a wide screen it zoom out big if any one know how to fix it or to tell me what i need please e-mail me at kcl22@hotmail.com thank you
  • deajohns May 01, 2009
    Anyone have any pictures locating the ICs for the P52960? I can only locate one heat sink in this thing, and it is connected to a Uxxx IC not a STKxxx. Also, the fl231 fuse fix sounds good, but I can't find this either in this tv, its a 2003 so it may have a different setup.
    Thanks,
    Devon
    Genius:
  • 1,030 Answers
I just read your post on fl231 comments. UNfortunately this only applies to the itc22 chasis
Posted on May 02, 2009
  • 4,234 Answers
Normally this is either bad connections on the convergence ICs or defective ICs. If you can solder, you should be able to fix this. First locate the convergence ICs: large black ICs attached to a heat sink that shouldbe marked STKxxx. Try resoldering the pins on these ICs first. If that fails, replace the ICs.
Keep me posted.
Dan
Posted on Nov 21, 2008
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
On our rca hdtv model # R52WH77.. the tv is having like a 3d look on it and has a bow in the picture.. we bought the convergance repair kit from tvrepairworld.com and replaced the 2 parts it gives us.. ...
have you reset the convergence parameters after installing the kit to fix the option? Usually you will need to reset the defaults to get the outer edges back in alignment.
Aug 11, 2011 | RCA R52WM24 52" HDTV Projection Television
My rca projection 52" tv
http://www.partstore.com/OpenSearch/Model/Thomson/RCA.aspx
Jul 07, 2011 | RCA P52960 52" Rear Projection Television
I have the RCA P52960 52 in. Rear Projection Television and the picture just started bowing from the top and bottom in the form of a bowtie. I the post and was wondering if there was a way i could prepare...
my name is steven. Its wierd that i have the exact same tv and it started the same problem on the same day. I can't tell you what is wrong with it unless it is just old like mine. Thanks for posting any solutions you find. I did take the back off it and check for loose parts. Everything is intact. I vacuumed the bulbs and the screen from the inside with a brush attachment and the picture is so much more bright and crisp but the bow is still there.?
Mar 20, 2011 | Televison & Video
My screen has a slight bow shape
its probably convergence -
here is my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
rca hint at the bottom.. it probably needs a convergence power board, easy install.. 4 screws and 2 plugs(wires)
Jun 18, 2010 | RCA P52960 52" Rear Projection Television
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
408 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
