Question about HP DeskJet 3820 InkJet Printer
Green and orange light flashing
The green and orange keeps flashing steadly when you turn printer on it wont feed any paper
  • 2 more comments
  • tiger52 Jan 08, 2008
    My printer will turn on but then the 'no paper' light and the power light will flash. Each time I hit the 'no paper' button, the printer will try to get a piece of paper but will not grab any. As I was looking over it I noticed that there is a piece in the bottom of the printer that moves up and down. I think that it has to be in the up position in order for the paper to feed, but there is nothing to hold it up, so it just fall down and the paper hits a wall where the peice was supposed be. I think that the piece was made at a curve in order to create a slant for the paper to go up, but since it always sits on the bottom, instead of the paper sliding up, it just hit 90 degree angle. Any suggestions on how to fix this?
  • Anonymous Feb 17, 2008
    i noticed that, on attempt to print, the printer will pick the paper alright, but no print is seen on the paper and the green and orange lights keep blinking unabatedly. i tried opening the cover and discovered that, the ink catridges dont move as the paper transits the machine.
  • Anonymous May 11, 2008
    Orange and green lights are blinking, and printer won't feed paper nor will it print. Don't tell me I can't fix this...
  • Anonymous Mar 17, 2014
    my printer wont work it is flashing 0 2 p the little orange triangle light is flashing next to the that the orange light by c is on and the a4 plain paper light is on green please help
  • 24 Answers
Ink buildup in the internal service station causes the small poorly designed pusher cogs on two drive gears to snap off and the printer is instantly converted to junk.
HP was giving new printers out for this problem till Jan 06 or so as they realized it was a poor design.
I fixed one with parts from an electronically damaged unit, but usually the blinking lights and "won't print no matter what" problem are sheared gears. Parts are not available. Some people made metal gears (the only answer) on a very short run basis in Europe several years ago because people LOVE this printer.
Once you know the problem, it's simple to keep it from happening with some maintenance, but once they shear, it's over.
There was some kind of paper-clip fix that was solving the problem even with sheared gears, but I was never able to understand exactly how it was done. Needed a pic or two.
Otherwise a great printer, huge cartridges last a long time, great quality on photos too.
I have to keep mine running to have a happy wife.
Posted on Apr 05, 2008
    President:
  • 2,961 Answers
Assuming there is no paper jammed, turn off printer and disconnect from usb port. Go to add/remove programmes and uninstall printer software and drivers. Go to printer and faxes folder or go through control panel and ensure the HP printer is deleted, if not right click and delete. Re-start pc and install drivers from your printers cd rom and re connect printer when prompted and not before (if no prompt when software finishes connect printer). Your pc should then idenitify your printer and auto install drivers. If the lights still flash then there is a hardware problem, probably not worth repairing, as printers are so cheap nowadays.
Posted on Jan 07, 2007
Paper will not fee, printer will not print
two cartridge inks at end continually flashing so is this why the paper wont feed?
Apr 21, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon IP4300 flashes orange and green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Oct 25, 2009 | Canon BubbleJet i560 InkJet Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
I keep getting a sequence of orange and green light flashes. The paper won't feed and the message i get is " paper thickness lever problem" HELP!
in the side where you load the paper you can locate a lever that is lifted when you place the paper. just try to get hold of it. move it in either directions and then restart your printer without paper.
and once again with paper. everything will be fine
Jul 04, 2009 | Canon i850 InkJet Photo Printer
Canon ip1300. Three orange flashes, one green.
Hi emdos,
Did you mean blinking three times in Orange?. Well, the problem is paper jam error occurs in your printer. First, check if any broken paper inside printer. If it so, remove broken paper. If problem still persist, it seems that drive assy broken or paper feed sensor fault. Find more useful article about this below.
Soruce:
Canon Inkjet Printer Forum
Nov 26, 2008 | Office Equipment & Supplies
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A DLFNA207@GMAIL.COM
Jul 16, 2008 | Epson LX-300 Matrix Printer
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
HP DeskJet 3820 InkJet Printer Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
