Question about Microsoft Windows Vista Ultimate Edition
About the Vista start
It doesnt work properly because when i start up and click the start menu
it will appear then it will hang permanently
  • 849 Answers
Windows gone corrupt, first check virus in safe mode by pressing f8 when starting up, if found any virus clean it, otherwise u may re-install windows.
Posted on Nov 20, 2008
Why were start menu and task bar lost?
Hi B.G.R.,
Have you tried
Pressing ALT or F10 in your keyboard to make the Menu Bar temporarily visible. If you want it to be permanently visible, go into View > Toolbars > Menu Bar, or right-click the Navigation Toolbar (the Reload button, for example) and select Menu Bar.
If this doesn't help, right-click the navigation toolbar, select Customize... and click Restore Default Set. If it doesn't appear right away, try pressing ALT or F10. You can go into View > Toolbars > Menu Bar to make it permanently visible, or right-click the Navigation Toolbar and select Menu Bar.
Sep 12, 2015 | Computers & Internet
Tip
Games Explorer link does not work in Windows 7 or Vista.
To open the Windows Vista games folder, you'd normally click on the Games Explorer link in the Start Menu.
You have to ensure that it appears there in the first place.
If it doesnt appear, Click Start > Rt Click > Properties > Start Menu tab > Customize > Select Games > Display as a link or Display as a menu > OK > Apply > OK
Incidentally, if you type Shell:Games in Vista's start menu search bar and hit enter, then too the games folder will open.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); But if the Games Explorer folder does not open in your Windows Vista, here is what you may try.
Type cmd in Vista's start menu. When cmd appears as a result, rt click on it and select Run as administrator.
In the elevated command prompt, type
regsvr32.exe gameux.dll and hit Enter. This will re-register the ganeux dll file.
It should help.
on Jun 25, 2010 | Computers & Internet
I have a acer laptop ASPIRE5520G .My dvd drive does not appear in my computer folder so that i can't use it. Please give me some advise. Thanks.
Below is the steps to resolve the issue:
CAUSE: Software that is not Windows Vista capable (such as printer software, CD burning software, and games) may have modified the registry to cause the optical drive to not function.
RESOLUTION: Method 1: Remove the program that caused the issue: If you know which program might be the cause of the issue or the last program you installed, remove the program.
  1. From the Start menu, click Control Panel.
  2. In Control Panel, click Uninstall a Program.
  3. In the Programs and Features window, click to select the program to remove, and then click Uninstall/Change.
  4. In the User Account Control dialog box, click Continue.
  5. Follow all onscreen instructions to complete the removal.
  6. Shut down and restart the computer after removal is complete.
Note: Determine whether the computer is working properly. If the issue is resolved, do not load this software again because it will cause the optical drive not to function again. Instead, contact the software manufacturer for a Windows Vista™ capable version.
If removing the program did not resolve the issue, use System Restore. Method 2: Use System Restore to restore to a date before you installed the third party software.
  1. Close any open programs.
  2. From the Windows Vista™ default Start menu, click All Programs, Accessories, System Tools, and then click System Restore. Note: System Restore can also be opened by typing Start Search keyword: rstrui.
  3. In the User Account Control dialog box, click Continue.
  4. In the System Restore dialog box, click Recommended restore, and then click Next.
    View Picture Note: If a different restore point is needed, select Choose a different restore point, and then click Next. Select a day and time from the list when the computer was working properly, and then click Next.
    View Picture
  5. In the Confirm your restore point dialog box, click Finish.
    View Picture
  6. In the System Restore dialog box, click Yes. The computer restarts and make the appropriate changes.
    View Picture
  7. After the computer returns to Windows, in the System Restore dialog box, click Close.
    View Picture
Note: Determine whether the computer is working properly. If the issue is resolved, do not load this software again because it will cause the optical drive not to function again. Instead, contact the software manufacturer for a Windows Vista™ capable version. Method 3: If System Restore did not resolve the issue, manually modify the registry.
  1. From the Windows Vista default Start menu, point to All Programs, Accessories, and then click Run.
  2. In the Run dialog box, type: Regedit. Click OK.
  4. In the Registry Editor window, locate and then click to select the following registry subkey: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
  5. From the File menu, click Export.
  6. In the File name dialog box, type: Savedkey, and then click Save.
  7. Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
  8. Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
  9. In the Registry Editor window, from the File menu, click Exit.
  10. Shut down Windows® and restart the computer.
Thanks and regards,
Anil.B.R
Nov 06, 2010 | Computers & Internet
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
http://www.softwaredriverdownload.com/try_fool_windows_vista_to_install_in_windows_xp_mode
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
Programs won't show up on pc
It sounds like there could be a program hanging preventing you from using the computer properly.
A quick way to resolve hanging problems with Vista (especially if your not computer savvy) is to perform a system restore.
To do this click on the orb (start menu), in the search bar type restore and then hit the enter key. A system restore window will pop up. All you have to do is choose a date that is before any problems occurred and take the computer back to that date. You may have to wait a while if the computer is still hanging.
Regards.
Nov 09, 2009 | Office Equipment & Supplies
Start up failure;
try to start in safe mode using F5 at the time of window booting
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
When computer is started up. Screen say windows failed because didnt shut down properly. It give 4 options. 3 safe modes an general windows vista mode. Connects to safe mode when u click on it. But screen...
You may have to use your RECOVERY disk that came with your system and re-install your operating system. I believe you can do it and still keep all your files you currently have.
Mar 15, 2009 | Computers & Internet
Blank screen, can only start programms by task manager
Try to boot Vista into Safe Mode. Tap the F8 Key right after you turn on the computer until you get the Advanced Boot Up Menu
and use the keyboard arrow keys to select Safe Mode. The next screen may ask you to select your operating systm. Select Vista, not the Recovery Console.
Does your task bar and icons appear in safe mode? If so, it might be one of your start up programs that is failing and causing explorer.exe to fail during normal boot-up into Windows and not allowing your taskbar and icons to appear. Click Start and type in msconfig and hit enter then click the Start Up tab and look at all the programs that start up when Vista is starting up. Do Not uncheck anything in the list that you do not recognize as you may uncheck drivers or Vista starting programs that you computer needs to start up Vista properly. Google anything you don't recognize and uncheck any Start Up programs you do not need to start when Vista boots up, like Quicktime player or Adobe Reader for example. (This would also help your boot up time into Vista)
Sounds like explorer.exe crashed. Try opening up the Task Manager again, and Click File > New Task and type in explorer.exe. See if the task bar and your desktop icons appear.
If they appear for a brief moment then disappear again, the Windows explorer.exe is corrupted. Explorer.exe will try to start and then fail again. You may need to use System Restore to bring your computer back to a date and time when the computer was working properly, before the Vista update.
Jan 31, 2009 | Computers & Internet
Slow performance - Frequent Hanging of system
Do you run the Aero them with the glass windows effects etc. and have the windows sidebar running? I have found that this tends to slow down my computer a lot.
To turn off Aero:
  1. Right click on an empty area of the desktop
  2. click personalize
  3. click window colour and appearance
  4. select colour scheme:"windows vista basic"
  5. click ok
To turn off sidebar:
  1. go to start-> control panel
  2. Click windows sidebar
  3. deselect "start sidebar when windows starts"
  4. click ok
  5. on the task bar right click the windows sidebar icon
  6. click close
Mar 08, 2008 | Microsoft Windows Vista Ultimate Edition
The wireless doesnt work
first open your device manager to make sure the hardware and the drivers are functioning properly. control panel add printes or other hardware, then system will be in the upper left side menu. then click on hardware, and then device manager. if it's working you'll see it under network devices but if not you'll see a yellow question mark that says ethernet controller. click it then click 8uninstall then the found new hardware wizard should start up for you to just reinstall the hardware.
hope this helps. keep me posted.
Dec 04, 2007 | Toshiba Satellite A75-S211 Notebook
Microsoft Windows Vista Ultimate Edition Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
