Question about Onkyo TX-DS898 Receiver
No sound from rear speakers
I am trying to set up a 5.1 system and find the receiver and the manual to be very confusing. If I hook up the rear speakers to the "SURROUND BACK/ZONE 2" I do not get any sound unless I change the configuration to "Activated". I have checked volume levels, etc, etc. If I set to "Activated", of course I am just getting stereo sound from those speakers - not surround sound. Am I correct that "Not Activated" should be selected for 5.1 sound in the same room with no Zone 2 speakers??
Could you please outline for me all the most common settings for setting up the receiver for 5.1. I have been trying for days to get this set up properly for use with my TV, CD player, and DVD player.
THANKS for any help.
  • Official Brand Answer
  • 333 Answers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Posted on Mar 27, 2017
  • 1512 Answers
SOURCE: Onkyo Zone 2 Problem
Hi there
The only reference i could find to this in the manual is on page 55, in your hardware settings. It relates to the menu settings for remote control configuration/zone 2 activation. Do you have a user manual to help you here? Hit the link above and enter an email address and you can down load one. Good Luck, any dramas,feel free to comment back to me here and we can sort it out)
Posted on Mar 08, 2008
  • 151 Answers
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
Posted on Aug 05, 2008
  • 12 Answers
SOURCE: onkyo 805 zone 2 problem
I just figured out what I was doing wrong last night. On the 806 at least, when zone 2 is not powered (receiver is set to act) there is a separate volume control 'level' that is on the receiver a couple buttons right of the zone 2 button. By default this level appeared to be set to -50db. As soon as I turned up this level sound came out of my zone two.
Posted on Jan 14, 2009
  • 144 Answers
SOURCE: TX-SR506 Bi-Amping
If you select bi-amping the device will use a second amp for your rear speakers, this indicates that in your setup menu you probably have deleted the rears (set to None). Try to find the settings for your rear speaker in your setupmenu and see if they are selected in normal operation.
If all fails, see if you can reset teh device back to factory settings, sometimes software can get confused after using for a while. Resetting should than fix most problems.
You can also check and see if there is maybe a software update available for your device, loading and installing is explained in either the file or on manufacturers site.
Posted on Apr 17, 2009
  • 757 Answers
Press and hold the VIDEO-1 button then press the SPEAKER A button and hold until "clear" is displayed. Then re-enter your setup menu, enable your surround speakers and if there is a decode priority select "PCM."
If your problems continue, contact Onkyo.
Posted on May 08, 2009
Looking for a Manual for this receiver. I can only find a Brochure online. Trying to hook up a pair of speakers to the rear channels - but getting no sound. Any Help? Thanks!
Click on this link. This link will give you many choices to get your manual. Good luck.
Jun 30, 2015 | Nakamichi Audio Players & Recorders
Front two speakers only working.
If you haven't done this already. Chrck that you have tha corrent system chosen. Click. On the sound icon use scroll to find your system. Then be sure it is set as default in your computer. Right click on the sound icon fans you will find a set up plan for both play and record. Choose the same system for both and make them default. Pleas configure as necessary.
Sep 26, 2017 | Yamaha HTR-5650 Receiver
I have a Pioneer VSX-D510 reciever with 5 speakers and sub. The sub keeps making continual popping sounds at higher volume levels when watching movies, tv etc. Have to turn most of the way down. Also,...
Manuals help a lot.
Tell us about the speakers. Maybe they're not compatible.
As far as what to expect to hear from surrounds, that depends on the sound engineering.
Test tones for speaker setup will get it all dialed in. Page 17.
Mar 05, 2011 | Pioneer VSX-D510 Receiver
Rx-v463, no sound from rear speakers, and hookups
Sounds like an internal software issue dealing with this may have to return it to the manufacture for this repair.
Jan 28, 2009 | Yamaha RX-V463 Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Having trouble setting up sound system
I can see by the setup of this device, it can be confusing. So let's make sure you are setting the device to the correct "A" speaker outputs. These would all be on the rear panel, on the right side of the receiver. Is this correctly setup?
May 26, 2008 | Marantz SR-7200 Receiver
Setup problem
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles:
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Apr 01, 2008 | Logitech Z-5500 Computer Speakers
Cant get rear speakers to Work AVR 745 7.2 Surround!!!
Another way to solve this rear speakers problems is to go to the equalizer and have the system recognizes the sound coming out of all speakers. The AVR 745 comes with a microphone on the stick, using that to run the manual equalizer. It is the manual equalizer will set the rear speakers.
Dec 29, 2007 | Harman Multimedia AVR 745 Receiver
Onkyo TX-DS898 Receiver Logo
66 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
