Question about Frigidaire FGB24S5A Gas Single Oven
My frigidair oven model # fgf316dsd Regulator problems
For some reason the 2 stage regulator didn't drop the pressure and I believe the ovens regulator came under extreme pressure. I replace the 2 stage regulator yet when I turn the knobs on for the gas (with the oven unplugged), the pressure is to high. The internal regulator can take what PSI....converting it to 1/2psi ? To replace on look like a lot of work,and $. What are your thoughts
Could I over ride the system with another regulator
  • seantienhaar Nov 20, 2008
    The override regulator is 1/2psi. is this the correct psi for most stove regulators?
    Sergeant:
    Champion:
  • 200 Answers
Hi
A burner doesn't work Heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in two, or blisters and bubbles.
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too. Also see the "A burner works only intermittently" section, next.
A burner works only intermittently If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range.
If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
I can't adjust the burner temperature If your burner always heats to "high" when it's on--regardless of how you set the burner knob--the switch contacts are shorted closed. Check the circuit for any other grounds, then replace the switch.
Thank you
Posted on Nov 20, 2008
    Genius:
  • 1,239 Answers
HI One pilot light usually serves all the top burners of a gas range. Some ranges have two pilot lights, one for each side of the range. A correctly adjusted pilot flame is steady and blue, between 1/4 and 1/2 inch high. If the flame goes out repeatedly, or if it's yellow at the tip, it's getting too little air. If there's a space between the flame and the pilot feed tube, it's getting too much air. To correct either condition, turn the pilot adjustment screw on the gas line slightly, as directed by the manufacturer of the range.
Most modern gas ranges use an electronic pilot igniter to start the pilot.
If the pilot flame is properly adjusted, but the flame doesn't ignite the burners, the problem is probably in the flash tubes that run from the pilot to the burners. These tubes may be blocked by spilled food from the burners. If this is the case, turn off the power to the range and clean out the tubes using a short piece of wire. Push the wire through the opening until the tube is clear. You may have to disconnect the tube to clear it. After cleaning the tube, replace it in the same position.
    Genius:
  • 1,550 Answers
Yes you can go with another regulator .
Thats good option than spending too much money.
My Frigidaire gas oven won't light but broiler does light
Hello friend, thank you for your post!
From what you are describing it sounds like a potential issue with your control or pressure regulator within your Frigidaire oven. I would recommend seeking assistance from a professional for further help regarding the oven not lighting due to the gas.
If you need assistance connecting with a professional technician you can visit the manufacture's website for further help. -Matt
Oct 04, 2014 | Ovens
Flame too high on gallery gas stove
Hello Carlos - Does you range have an LP conversion kit installed? If so, I would recommend verifying that unit is set to appropriate fuel and fuel conversion kit is finished. Also trying adjusting the pressure regulator and/or air shutter.
Sep 16, 2012 | Frigidaire FGB24S5A Gas Single Oven
I have a Viking gas single oven with four burners. The burners work fine but the oven won't fire up. I smell gass an I see a glow under the oven but no heat. But if I turn it to broil I get some heat but...
I had the same problem with the single oven, It the voltage feeding the oven, it like to be 120 or above if it drops below 120 then this problem occurs. I had ever thing checked, gas pressure, and the oven. Electrician installed a voltage regulator on that circuit.
Dec 30, 2010 | Viking Ovens
I have a Frigidaire gas stove model FGF337BCGL. It makes a groaning sound when I first turn on the stove top also when i turn on the oven. Sometimes it does the groaning 15 min after being turned on. It...
The groaning your hearing is the internal gas regulator. It is nothing to be worried about unless your having problems with the size of the flame whn the oven is in use. The groan is the gas passing under the diaphram and the diaphram is gently vibrating against the regulator mating face. It can be annoying but really nothing to be concerned about. If you really want to rid yourself of the nuisance you can either have the regulator changed (legally) or change it yourself:
The regulator is item 14 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151291&diagram_id=1241169#d1241169
My thoughts are as a 35 + year in home repair person is: Unless there is some other problem.. do not be too concerned.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Ovens
How do I change my oven to propane on the regulator
Many of the regulators can be changed by simply taking out the center plunger and flipping it over and reinstalling it...
You still should make sure that you check the pressure afterwards...
heatman101
Mar 26, 2010 | Frigidaire Ovens
Gas ranges low pressue propane? 2 of them
The problem is with the tanks or the pressure regulator.. Call your propane provider and tell them what is going on. they should come out and replace the regulator and check the gas line for kinks or partial blockage.
Jul 11, 2009 | Kenmore 30169 Electric Single Oven
Hello. I have an old Roper oven, model no.
The ignitor draws amperage thru gas valve which opens the bimetal valve to release the gas.Round ignitor 2.75 amps. Rect. 3.5 amps.Bottom line if burner dont fire within 60 seconds of turning orange you have a weak/bad ignitor.Hope this helps.Please rate my response :)
Jun 20, 2009 | Ovens
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Frigidaire FGB24S5A Gas Single Oven Logo
55 people viewed this question
Top Frigidaire Ovens Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
