Question about Whirlpool ED2FHEXNS 21.8 Cu. Ft. Side-By-Side Refrigerator w/ UltraEase¿ II Water Filtration System:...
Whirlpool ultraease warm on left side, dispenses warm water
My 8-year-old Whirlpool Ultraease side by side refrigerator has been dispensing warm water off and on over the past 2 weeks. I've also noticed that the left side of the fridge (the freezer side and side the dispenser is on) feels warm to the touch (the right side feels normal). Is this dangerous? Can it be fixed?
  • Whirlpool Master
  • 2,651 Answers
Not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Posted on Nov 20, 2008
Ice maker not dispensing
This is possibly only a defective micro-switch on the Dispenser Module. Can you post the model number so I can examine the correct parts?
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 16, 2014 | Refrigerators
How to remove icemaker from whrilpool ultraease refridgerator
I had a simular problem with my Whirlpool frig--First of all I would check 1/4 inch plastic line coming from water valve up to ice maker,loosen this line & try to blow thru it -if there is an obstruction it probably is frozen inside plastic fitting at top where it goes thru cabinet & into ice maker if so you can melt by by running a very warm metal object up & inside fitting be patient, you need to both inside & outside--If this the problem,your water valve is probaly bad because of not shutting off properly causing the "drip effect" you can purchase valve on line for aprox $10.00--$25.00 Good Luck--John Morris--
Feb 08, 2013 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Filter for UltraEase water filtration system?
This may not be the problem now but by the sound of the malfunctioning water lines etc., it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at
Jun 08, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool 21.7 cu. ft. Top Freezer...
"pipe hammer" from water line to in door ice/water dispenser
try to turn down the valve that feeds your refrigerator water inlet to see if that can help. It's most likely that you have too much water pressure feeding the unit and the valve is having a hard time closing off the flow of water. Good luck and have a Happy New Year.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool Conquest UltraEase Plus Water Filtration System ice dispenser
ngfam1 here for you!
I am happy to be of assistance!
It is not worth doing it your self!!!!
Sometimes its not easy to find out what part is bad on a
side X side with ice and water on the door, even for the trained tech. call service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Aug 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Jun 12, 2008 | Whirlpool ED2FHEXN Side by Side...
External water dispenser on Whirlpool Conquest model GS6SHAXKS01
Try this first. In the inlet side( where the little water line comes in) there is a small screen where the water is hooked up. Shut off the water and unhook the water line. there should be a small screen to keep out particles from entering your ice make/ water dispenser. See if that screen is plugged. If so clean the screen. you can put it in vinager over night if you want. It will help clean it.
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
336 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
