Question about HP PSC 1510 All-In-One InkJet Printer
Printer will not communicate with computers
My HP PSC 1510 does not communicate with my computer at all. I've tried multiple USB cables. The printer turns on, the copier works fine but when I plug in the USB, nothing happens. I have reinstalled the software and drivers. I uninstalled everything and plugged in the USB, trying multiple ports and the computer does not respond at all. I have tried this printer on 2 different PC's and I am currently trying to use it on a Macbook. Same result with every computer. It's the printer.. I believe in the hardware. It worked fine about 3 months ago but I haven't used it in a while and now it does not work. When the software looks for the USB, it claims "No devices found." I've used all USB's with other hardware and they work just fine. Is there a rest button or something on the printer? Thanks so much!
  • Kindel Stubblefield Dec 17, 2006
    I solved the problem by using a USB1 cable instead of USB2. Not sure how the cables got switched but I'm so happy it worked!
Install with the apprropriate driver software
Posted on Feb 07, 2008
Top three suspects
1. Printer data cable 2. Network not setup 3. Need to reinstall printer
Jan 31, 2011 | HP PSC 1510 All-In-One InkJet Printer
I need a windows cd to download a hp 1510 printer I don't have acd to download to the computer I need assistance to get it downloaded
go to HP.com on another computer and save it to a USB flash drive. you can then install it on that computer from the flash drive.
Aug 11, 2010 | HP PSC 1510 All-In-One InkJet Printer
No scan with imac
Make sure that the hardware is functioning correctly.
Restart the product and the computer
Manually check the USB connection between the product and the computer
Make sure that the USB cable is connected correctly to the product
Test the USB connections and restart the computer
The USB cable is connected to a USB hub or a docking station for a laptop
or Desktop.
Fully uninstall and reinstall the HP software
Use the MSCONFIG utility to enable the Startup software
Try the scan again
If the scan is successful, the issue is resolved.
Aug 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
I can scan, BUT I can't print. HP PSC 1500 windows 7
Go to control panel and check the printer status, Unplug the USB cable than right click on printer icon and click on delete. Once you do that make sure printer icon should be gone. Than restart the computer. Once computer is Up than connect the USB cable of printer and make sure while doing that , the printer should be powered on. After that printer icon will again reappear in contro panel.
Try printing, it should work
Jul 22, 2009 | HP PSC 1510 All-In-One InkJet Printer
Can`t print with HP PSC 1510 All-in-one in win. Vista
I would check to see if HP has Vista drivers for your printer.
Jun 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Using multiple HP printer models with same Windows XP laptop
I doubt there is a universal driver , however you could connect directly to your pc or via a router and share it over your home /business network, and access it them that way
Feb 13, 2009 | HP Office Equipment & Supplies
I have a hp psc 1410v all in one i cannot get it to communucate with my computer
Go to control panel - printer and faxes and check if the printer is listed or not. Make sure the printer is set as default printer. Try different USB port and lastly uninstall and reinstall the printer.
Thanks
Jan 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Lost software.. download available?
Click software and driver downloads on the page below and follow instructions:
HP PSC 1510 All-in-One Printer
Dec 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
Whenever I have seen this problem it has usually turned out to be one of the solder points on the USB connection in the printer. Of course it could be a logic board problem as well. Well done for testing your problem so thoroughly (eg trying different cables and machines) but I think it needs a repair agent now unless it is under warranty (or you can solder well). Mind you it's probably cheaper to purchase a new one then to pay to have it repaired.
Feb 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hp psc 1510 all in one printer
xax! as it seems u have tested a lot of thinks! :)
well, listen first of all if u have the cd of the VISTA instaligation pack u shoulld install it from there,
after that, u can tru to unplug the usb cable from ur computer so it has no conection att all, and when it says to plug ur printer, plug first into the printer and THEN into ur pc...(this is quite critical)
more over, do not be mad with the setup soft cause as it seems its not the best :S
e.g. ive instaled it 4 time to my pc cause i got an error in every step!!!
dont forget to vote!!!
Stratos
Nov 27, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
