Question about Pioneer DVR-107D DVD±RW Burner
My problem is that my system does'nt show any dvd drive in lapto
Hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
  • 6 more comments
  • jbaoweidan Dec 18, 2008
    hello, my hp laptop does not show the DVD drive.
    I have a pioneer dvdK17b. i removed the driver, reinstalled it, no help.
  • ericmcconvil Dec 27, 2008
    same issue, were you able to resolve? If so, how?
  • luckeee Jan 21, 2009
    laptop doesnt reconize the DVD the driver software is up to date?
  • pksi Jan 23, 2009
    I have the same problem. Could be a problem the Windows Vista 32 bits SP1 update?
  • magic1053 Mar 15, 2009
    I have the same problem. The drive worked fine for a year. Now I have the yellow alert and tried to reinstall the driver. No luck any suggestions?????
  • luckeee May 11, 2010
    No i haven't been able to resolve the problem?
  • phillip Jan 15, 2013
    You cannot just remove a driver, it has to be taken out of the registry as some files may still remain. then restart and reinstall
    Firmware update at. http://www.pioneerelectronics.com/PUSA/P...
    President:
  • 2,600 Answers
Follow the below very carefully....it usually fixes these problems. If there are no upper filters, don't worry....just delete the lower filters or vice/versa...get rid of the filters....just follw the guide below. When you get to the registry entries below, the first one maybe the one you need to edit...just read the numbers carefully to make sure you get the right one....it is easier than you think...you can do it!!!
Windows Vista
  1. Click Start
and then click All Programs.
  1. Click Accessories, and then click Run.
  2. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  1. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  1. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters
    only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. Exit Registry Editor.
  8. Restart the computer.
Posted on Jan 05, 2010
My laptap is hp pavillion dv6000 window vista system but i replace dell system .ineed to operate oreginal system
for this u must be having 2 soutions.
1. in the harddisk itself there would be a partition called as the recovery
try recovering your system. it will change the OS original factory settings.
2.u might be provided with an original dvd of your OS. try formatting with it.
Jul 03, 2010 | Microsoft Windows Vista Home Premium with...
Laptop HP Pavillion dv6647nr (a dv6000 family) F11 key Problem
Did you format the drive or just repair it"??
Access BIOS and have a look in case that key stroke is disabled in there.
Sounds like the CD has overwritten that part of the HP registry....they have their own.
Mar 12, 2010 | Computers & Internet
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
The driver for the device would have been corrupted by some incompatible drivers loaded onto your pc lately. It could also be that the device has been mistakenly disabled. If not, disable the device and restart your pc. After it stabilized on the desktop, go back to the Device Manager and enable it again. If nothing still happens, go through Control Panel and remove the driver from installed programs. Shut down your pc and disconnect the device. Leave for about 10 minutes and recoonect and power on the pc, the device should be detected by the pc and then install its drivers. If it doesn't detect the device, it has probably gone bad and should be replaced. Good luck
Jun 02, 2009 | Pioneer DVR-107D DVD±RW Burner
HP Pavilion dv6000 OS(s)
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
Mar 30, 2009 | HP Computers & Internet
My problem is that my system does'nt show any dvd drive in Lap
I had the same problem, it occurred right after windows installed sp2 and my laptop showed no dvd player with any program, I restored my laptop to the previous day before the update and it worked fine again, after that I just let windows update by itself and it has been a week and everything is fine, also in device manager open the dvd + sign and right click your dvd and click update drivers, if that does not work, right click your dvd, and then click delete, and then reboot your computer, laptop whatever and the computer will automatically recognize the player on startup and it will install again and hopefully that will get your drivers updated, do not worry about deleting the dvd player, it will reinstall all by itself, just have to reboot..thanks
steve
Nov 20, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneeer DVDRW-K17B ATA Device
hello
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-107D DVD±RW Burner Logo
588 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
