Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Changing a Whirlpool Washing Machine Control Panel
I need to change a Whirpool Washing Maching, ours got dented. I have the replacement panel, but I am not sure how to install it. I have partially detached the current the panel, but I am unsure how to disconnect it from the wiring that goes to each knob. Any advice?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll be able to uninstall all the knobs(screws behind the knobs), then take off the switches from the panel without really needing to take wires off the individual switch.the timer is a tricky knob to remove (there is directions printed in the palstic housing of the timer back itself explaining how to release the kob
Posted on Nov 20, 2008
Refrigerator whirpool is only working after tapping on the front control system panel? which part has to be replaced?
Whirlpool side by side fridges with the control panel across the fridge section have thermostats that will fail. Tapping on that control panel will cause the fridge to work temporarily. You will need to replace the refrigerator thermostat if you see small black specks under the thermostat.
Oct 21, 2016 | Whirpool Refrigerators
How do you unlock a whirpool duet control panel?
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Washing Machines
How to get back panel off the whirpool GSW9800pw2 washer
You wouldn't want to.. It's designed for all the work to be done from the front. Unscrew 2 screws on the back of the control panel, you can then swivel the panel up.
This reveals 2 big brass clips at the back of the outer body of the machine. Pop out the clips, the whole front & sides assembly simply rolls off. (Remember to unplug the lid switch at the back right under the control panel)
May 25, 2014 | Whirlpool LSR5132J Top Load Washer
How to replace the timer for Whirpool Model lsr6332kq1 washing machine, low water
watch the FIRST 1 MINUTE 10 SECONDS of this video if will show you how to disassamble the control panel,the rest of the video wont be revelant to replacing the timer but it will help to get into the control panel
First step before opening the control panel is to push in the timer knob and unscrew the knob in a counterclock wise direction and then pull the dial off, a screwdriver can be placed behind the dial to assist in removing it. Under the dial are the screws that hold the timer to control panel
here is that video http://youtu.be/9K1KHEogf3c
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Whirlpool Washing Machines
Whirpool front loader washing machine,. my control panel is stuck on "control locked" position. How do I unlock my washing machine?
Dont know the model but try and unplug for a awhile aand see if that does the trick if not call whirlpool or check out thier site
Feb 15, 2011 | Whirlpool Washing Machines
My AWOD6827 Whirlpool washing machine drips water from below the control panel. I have put the machine through a cleaning cycle with soda crystals and cleaned out the fabric conditioner compartment as...
AWOD6827 Whirlpool washing machine drips water from below the control panel This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2011 | Whirlpool Washing Machines
Getting the F21 flashing on my Whirlpool Duet Washing maching
To know what the f21 means, You need to see the fault code list; this is on a tech sheet that is usually taped to the back of the machine, orit is in the contol compartment that you will have to open to access. Note: the newer whirpool units have end caps that must be removed by light prying in order to access the screw on each side that releases the component compartment . Goodluck, Macgivor
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer throwing H the F code
f06 usually means problem in motor speed circuit either main control or motor control or possible wiring connections..FH is usually a problem with the flow meter left side under top has small hose from fill valve and one to dispenser...it's not reading water flow to machine a light tap may help confirm problem if doesn't help may need to change flow meter anyway small switch on small bd with wires will stick and not signal main bd there is water flow
Sep 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
