Question about Acer Aspire 5600 Series 5630-6951 Laptop
I UPGRADED WINDOWS FROM XP TO VISTA I HAVE NO VOLUME AT ALL
I AM USING ACER 5610-4179. I HAVE UPGRADED WINDOWS FROM XP TO VISTA . BUT I HAVE TROUBLE SHOOTING IN VOLUME. MY LAPTOP HAS NO VOLUME
  • jaguar8o15 Nov 27, 2008
    camera and photo
Acer aspire 5310 Wireless LAN indicator light on windows 7
That sort of comes with a OS upgrade, in upgrades from XP to Win 7, I'm supprised that's the only thing that is a issue. I upgraded a old gateway (2005) from XP to Win 7 Pro N 64bit. and had some hardware issues to deal with. Consider yourself lucky. You can get use to it or search endlessly for a fix. Try the Acer forums, you may run across the issue.
Dec 27, 2012 | Computers & Internet
I have acer aspire 5583 Laptop and sound driver is not supporting. After downloading the audio driver i have tried a lot to load the driver but it is not loading.
we need to know what operating system you are using on the laptop. If you have recently upgraded the laptop to Windows 7, you may need to re-install Vista or XP as your sound chip may not be supported by Windows 7. Go to the ACER website and look under the support tab..
Jul 08, 2010 | Acer Computers & Internet
Acer Aspire x3200 vista 64 bit upgraded to windows 7 32 bit. Coprocessor now has a yellow exclamation make. I have tried to update the driver but it cannot find any.
better wa y is to downgrade your OS back to Vista 64bit, the problem with windows 7 is that most of the drivers operational to xp and vista are still not supported by windows 7.
Oct 31, 2009 | Acer Computers & Internet
Recently upgraded from xp to vista... webcam doesn't work!!
You need to download the vista driver for the camera
Aug 15, 2009 | Acer Aspire 5610-4648 Notebook
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
