2000 Jeep Cherokee Logo
Posted on Nov 20, 2008
2000 Cherokee Heater only works once the vehicle is moving
My 2000 Chrokee blows cold air untill I get moving. I let it warm up for about 15 minuts. The engine is at opperating temprature. The fan works at all speeds. All controls function normaly. No warm air comes out untill I travel about 100 feet then warm air comes out
Anonymous
Level 1:
  • Contributor 28 Answers
  • Posted on Nov 20, 2008
Anonymous
Contributor
Level 1:
Answers
28
Questions
0
Helped
21608
Points
71
This is normal, heat comes from your motor so it isnt hot enough until you start working the engine
1helpful
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Heater turns from hot to cold
Have you checked the coolant level?
Heater slow to warm up 2000 528i
Have your thermostat checked, sound like it is not working when cold.
3helpful
2answers
I have a 2000 Grand Jeep Cherokee Laredo (6cyl). It was blowing only cold/luke warm air. I replaced the thermostat. Still blowing the same only now the radiator cap is cold but hoses are hot. ...
It is likely you have air in the system. Park on an incline, take the radiator cap off, start the car, let it warm up until the thermostat opens, fill the radiator until it stops going down. See if that doesn't get you some hot air. If not, try the other steps I have in my post at http://www.fixya.com/cars/r6235876-no_heat_fan_blowing_cold_air . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me.
2005 jeep garnd cherokee rocky mountain edition is just blowing cold air.I will not heat up untill you drive the vehicle. Any suggestions?
If the temeperature gauge says the engine is warm but the air is not warm until you drive it would most likely it would be the heater core partially clogged. Have it flushed.
Please take a moment to rate my answer .........Thanks
2004 toyota celica will not blow hot air for twenty minutes
If the engine temprature does not reach the normal level as it used to, it may be the coolant thermostat.
Iif it does, it could be air diverter gates not working properly, cold air blowing at a a light could point to that. The diverter gates are located under the dash.
It also coul be the valuve that controls the water to the heater core, but unlikely cause of the cold air at a light.
1helpful
Plenty of air but no heat one side of dash use to blow hot air. Now neither side blows hot air. 2000 jeep grand cherokee coolant is fine driver side seat heater doesn"t work air bag light comes on every...
Check to see that the blend door linkage is hooked up. Doubtful it is heater core, as you had heat to one side and not the other. Check coolant control valve linkage, verify it is moving the coolant valve from off to on when you switch temperature from cold to hot. Verify you have coolant flow to the heater core by feeling the heater hoses where they enter the firewall. If all checks out well, then look at hvac controls individually.
1helpful
Heater slow to work
this sounds normal in very cold conditions! The air is never hot when you first start the car in any car, until the engine warms up, then the heater air will also warm. You could check your anti-freeze level for the first thing. If you don't have enough anti-freeze, it won't run through your heater to give you the proper heat
5helpful
2answers
2005 Pathfinder Heat Flow problem
I am having/had the same problem. My rear heater has not worked the last 2 winters, still trying to figure that one out. But I think I solved the front heat problem myself. The heater was blowing cold air while idling and hot air when the car was moving.
I jacked up the front of the vehicle, took the cap off of the reserve tank for the radiator, turned the car on and ran the heat (AC off) for 15 minutes. This is supposed to release any air bubbles in the coolant system and I did see air bubbles emerge as I was watching (this might be normal occurance, I'm far from a mechanical expert). Anyway, this did not immediately solve the problem, still blowing cold air as it sat there idling after 15 minutes. Dejected, I put the cap back on, lowered the vehicle and resigned myself to taking it to a dealer.
But a funny thing happened the next day, the coolant level was a lower (no leaks on the floor) so I filled up, and sure enough, when I started the car and let it warm up a little, hot air started coming out of the heater!!!
As far as my wife knows, I fixed the problem for the price of a bottle of coolant, so I am a hero...but at first I thought it didn't work. Here we are a month later and still blowing warm air and haven't had to replace any more coolant...the internet is a wonderful thing!
Hope this works for you, and I hope I can figure out my rear heater problem as well.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
