Question about HP f2105 21" LCD Monitor
My hp w2207h goes to sleep
New hp w2207h goes to sleep as soon as we turn it on if you disconect the cord to it check video cable
  • Anonymous Apr 29, 2009
    if the monitor is turned off and on again, it flashes and says "check video cable" it never fully re-established the signal from the Mac G5 DVI
    Same issue occurs if trying to use a DVI switch.
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Posted on Mar 11, 2009
  • jhayssonne Mar 11, 2009
    To unlock the OSD or
    just press menu for about 10 sec. until the osd menu pops out.
Hi, I have the same problem, it "goes to sleep as soon as I turn it on", plus OSD lock out keeps flashing. I noticed this happened when I was trying to install Windows Vista.
Posted on Nov 28, 2008
I have a hp w2207h monitor. When I turn on my computer the monitor shows "Monitor going to sleep". everytime I turn it on. What can I do?
Wake it up. No, seriously. What you see is most likely the video signal not getting from the video card to the monitor. When that happens, the monitor takes a nap. Problem could be a loose cable, sleep setting on the computer, or bad video card. Check each of these in the order I listed, as they are easy to hard.
There is a slim chance that the monitor indeed has a problem. Rule out the other possible issues before jumping to that conclusion. If you ultimately believe it to be the monitor, try to borrow someone else's monitor to see how that one reacts.
May 10, 2014 | Computers & Internet
How to fix
tried to hooked up with other monitor just to ensure if the cause is your pc. if the monitor doesn't receive signal it will goes to stand by mode.
Sep 07, 2012 | HP W2207H 22-inch Widescreen LCD Monitor
Monitor hp w2207h falls asleep within minutes of rebooting
check the on screen menu on the monitor that you havent got a sleep timer set or aggressive power saving on. Also check on your pc that you dont have it set to turn the monitor off after two minutes
Mar 04, 2011 | HP w2207 Monitor
Hello: Just recently, the 2159m HP monitor goes to sleep in the middle of an activity. This happened on two desktops and different settings. Repalced the video card, adjusted settings, replsced DVI...
Check the cord and connections for the monitor; this has one wire that must have voltage on it or the monitor goes to sleep, and a broken wire or loose connection will fool it into thinking you are powering down. If this doesn't work try going into power options and setting monitor to never power down.
Jan 22, 2011 | HP 2159M Monitor
At start up my monitor goes to sleep and stays. hooked up another monitor and it did the same thing. hp pavilion a6600f PC and hp w2207h monitor
the most likely issue is the computer's graphics card. to avoid extra problems, try replacing it with the same model graphics card.
Sep 27, 2010 | HP Pavilion a6600f Desktop PC
As soon as i turn on my computer my monitor says no input signal and then goes to sleep i have an hp
either your video card has stopped working or your cable to your monitor or the monitor is bad. Try to hook another monitor up to it see if it turns off if it doesn't then the video card needs to be replaced. If it does its the monitor.
Mar 07, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
As soon as i turn on my computer the monitor goes into sleep mode
try another cable I have tis problem on mine & I have to do them up solid, also check for bent pins in the cable & bend the back carefully & unplugged.If not you may need to set up the computer to output, try another monitor to rule that out.
Hope this helps!
Sep 22, 2009 | HP Pavilion F1703 17" LCD Monitor
Sounds like your video card is failing. If the video is internal to the motherboard, get a video card and add it to the motherboard if there is an open video slot available
Mar 13, 2017 | HP Computers & Internet
Computor won't stay in sleep state.
remove the serial bus cable and reinstalled the software that came with it,itmay be infectted by virus
Nov 17, 2007 | Belkin (F6C800-UNV-PL) UPS System
HP f2105 21" LCD Monitor Logo
2,288 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
