I have a PX-230A CD-R and a PX-740A DVD Player/Burner. Recently my computer stopped recognizing the two drives. I got the following message when reviewing the device manager: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39. I don't have a clue how this happened. I cannot re-load the Windows drivers because I cannot access the drives. I would appreciate any help you can provide. Mark Oliver
    Problem Solver:
  • 6 Answers
Sir insert the operating system cd inthe cd rom drive .and restart the system press del booten goto bios goto boot dives change frist boot devise to cdrom drive and press f10 tosave thesettings
ofter the proses disply shoes press any key to continy plese press any key in key board
ofter copying the system files one message press enter to contenu . press R for REPAIR .PRESS F3 plesr prese the R bouten to repail the os........ ofter 10 minutes your system will be restart anther 25 minutes complet your system repairing ok na
Posted on Nov 20, 2008
Failure to spin up drive. Drive door will not open when front button pressed but does show up in Drives under My computer. Checked cable connections and power. The green light on the front turns on for a...
Will the door open if you press a paperclip in the little access hole on the front? There is a lil rubberband inside that has prolly stretched not allowing the door to open.
Jul 15, 2011 | Plextor PX-230A Burner
Drive won't play blu ray discs but will play DVDs. Hooked up to Samsung R580 Laptop.
Windows Media Player does not play Blu Ray discs. You need 3rd party software such Cyberlink Power DVD. Follow that link and you can download a 30 day trial.
Mar 20, 2011 | Plextor PX-B120U External Slim Blu-ray...
PX-810UF DVD-RAM Burner: is not recognizing the size of blank disk...
try Burning software It will automatically find out the size
May 06, 2010 | Plextor PX-810UF DVD-RAM Burner
Plextor px-708a will not recognize disks. Just removed a second DVD drive from the system and jumpered px-708a as MASTER. The system recognizes the drive; it just will not read.
as you've changed the configuration of the drive from slave to master you need to go into the bois and change the settings for the drive so that it reads the px as master cd drive
Feb 25, 2010 | Plextor PX-708A DVD±RW Burner
My HP computer does not recognize the Plextor PX-880U DVD Drive
Try getting new firmware from Plextor and see if that doesn't help the problem.
Feb 06, 2010 | Plextor (PXW5224TAT3BP10PK)...
Error after burning
could be the software. try re-installing. make sure you are not doing anything elce on the pc while your burning if your pc is a bit old or slow
Dec 01, 2009 | Plextor PX-740A (00765075107763) DVD RW...
The plextor dvdr px 708a stopped working
Thanks for coming to FixYa, The problem you have is either a well documented software problem, corrupted plextor software or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then try re-installing the plextor software. Again if that doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 16, 2009 | Plextor PX-708A DVD±RW Burner
My Plextor PX-230A CD RW Drive just stopped working. When I put a CD in the drive, the green run light just stays lit as if it trying to read the disk and eventually stops without anything happening....
More then likely not, just a reg error, Try this click "start" "run' type in "regedit" then ok, in the feflt field click the "+" next to "Hkey_Local_Machine" + next to "System" + next to "CurrantControllSet" + next to "Control" + next to "Class" click on {4D36E965-E325-11CE-BFC1-08002BE10318} in the right field, right click on "Upper Filters" then "delete" right click on "Lower Filters" then "delete" restart pc. Hope this was helpfull. GL
Jun 25, 2009 | Computers & Internet
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
Dec 18, 2007 | Plextor PX-740A (00765075107763) DVD RW...
Plextor PX-716A will not read discs
the problem could be in he media player settings, check them and change as required. its pretty self explainatory.
Dec 09, 2007 | Plextor (PX-716A-BPS) DVD RW Dual Layer...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
