Hi! Today I put a cd in my HK DVD31 and started playing. After about 10-15 seconds it froze, no sound and the display showed the time the cd froze. I turned the DVD off and on again, still the same display message and no button other than the powerbutton is responding. I now plugged out he powerchord and when I plugged it in and restarted the dvd everything is black except from the blue light by the "on" button. Still no other button is responding and I can't get my cd out either. Is there someting I can do?
/Andreas
Comments:
Dec 15, 2006
- The thing is...I can't get the tray to open either. So trying a different one is impossible at the moment.
-   i turned my dvd player on and put a dvd into it. after the dvd went in there was no display and i couldn't get the dvd out. it was like it didn't have any power so i unplugged it and plugged it into a different outlet still no display and no dvd.-   tstd
try another dvd if the same your laser pick-up is defective . You could try a cleaner ,but in most cases if this works it is only temporary. Unfortunately the laser in all likelyhood will have to be replaced. Can be expencesive .
Was this helpful?
Yes
No
Solution #2
posted on Feb 20, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Mine freezes, and I have to unplug it from all electrical sources for it to begin reading again.
I'm having the same problem viewing DVD+RW discs. the DVD plays for a while then freezes. I've seen plenty of bad advice on this topics. Most people say "your laser is weak / dirty" and that is bullcrap. A weak laser won't freeze your whole player, and BTW, what standard are people using to comapre weak lasers to strong ones? And really, does the inside of your player get that dirty?
The problem of the whole player freezing up like you mentioned is a manufacturer defect for the player. You should return the product for a replacement. They will give you hassle about it, but stay strong!
To get your disc out, there should be a small pinhole by the tray. Poke an unbent paper clip in there to unlock the tray and then slide it out. You should be able to retrieve your disc.
lost power to dvd only had 3 weeks model no BOP 3000/05 tried changing batteries in remote control...
(More)
lost power to dvd only had 3 weeks model no BOP 3000/05 tried changing batteries in remote control tried changing fuse and tried different socket however still no power.
hi bought home entertainment system today mod no 40093 i want it to go through my tv i have virgin...
(More)
hi bought home entertainment system today mod no 40093 i want it to go through my tv i have virgin media cant seem to get speakers or dvd to work with telly
dvd 31 will not play or eject DVD. It is stuck in Resume mode. the only button that works is the...
(More)
dvd 31 will not play or eject DVD. It is stuck in Resume mode. the only button that works is the power on/off (and it is sporadic). I've tried to unplug and see if that works but no luck. DVD is stuck and not able to play.
it is new.
The first time I switched it on, the disc drawer opened and I placed the DVD.
It...
(More)
it is new.
It didnīt close despite I tried with the remote and the with button in the
front panel.
At the same time the display shows "Reading" and then "no
disc", as it was unable to read the disc (obviously considering the disc
was outside the player).
Then when switched off the drawer remains out.
When I turn the player on again, the drawer tries to go back, but remains in
place. Note: I switched it off, placed manually the drawer inside and when powered again, the drawer came out and had the secuence.
