She6af02 is the model number
SOURCE: Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
SOURCE: What is error code 2H
doesnt sound like an error code it sounds like its the delayed start feature, not sure that bosch ever used error codes
SOURCE: I do not have an owner's manual for my Bosch
Problem is now solved. I found the manual on your web
and downloaded the entire 32 page document.
SOURCE: Bosch Dishwasher Model SHU5316UC-06 -- what does
2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
SOURCE: My one month old Bosch dishwasher Model SHE6AF06UC
think this means that your water pressure is not high enough for rinsing to be completed 100%. do you have low water pressure.
