Question about RIM BlackBerry 8800
USB connection failure to Blackberry 8800
Hey
when i try to connect my Blackberry 8800 to my computer per usb cable neither the computer or my blackberry recognizes it
i tried it now on diferent computers always with newest BB software installed and on direct usb but it never worked
any solutions ?
  • 1 more comment
  • AndrewBL Dec 01, 2008
    My BB8800 USB port has failed. No charging or syncing. Is there a fix?
  • Anonymous Dec 01, 2008
    the internal usb-port is broken.
  • Anonymous Mar 01, 2009
    my blackberry wont detect the usb connection and i need to download a song
I have the same problem.  The following solution may apply; here is how to IDENTIFY the problem: (1) Phone doesn't connect to desktop software through USB but will through BT (if setup) (2) Phone doesn't charge whether USB-computer, USB-wall, USB-carcharger or does sometimes but you are not sure why it works sometimes but not all the time (3) If you hold, lean, twist, or jiggle the plug at the phone, it may charge or the charge icon may show briefly (Also) Plug is noticeably loose or comes out Solution: if plug is torn loose, damaged, or comes all the way out, go to this site and follow along in kind http://computerguru365.blogspot.com/2006/02/diy-blackberry-usb-repair.html If plug is simply intermittant: remove all power and the battery, open your phone, and carefully redo the solder joints of the plug.  If you don't have a SMT (surface mount) rated soldering iron w/ tip, you can use the radio shack standard but be sure to only apply the hot tip in pulses (less than/up to 50% of time, less than 3sec each touch) so you don't heat damage the surrounding components. Why: Because the plug gets tugged to the sides causing the solder joints to crack (microscopically).  At first I had to lean books against the plug but then that quit working as well.
This approach also worked on my laptop which quit charging when plug torque flexed the motherboard and cracked the solder at some surface components near the plug.  I found out which components when the varying the force of my multimeter tip cause the component to show open and normal across the solder joint
Posted on Dec 14, 2008
How to canect pc
Your Blackberry might have a USB cable to connect to a charger, or USB adapter. for charging. If so, plug that USB cable into the computer, and it should be seen by the computer. Turn the device on so it will be seen.
If all you have is a charger cable that goes to a 110 outlet, you'll have to get the required cable. Do a search online for "blackberry to usb cable".
Or try this search for other ideas: https://www.google.com/?gws_rd=ssl#q=blackberry+to+pc+usb+cable
Nov 26, 2015 | RIM BlackBerry Curve 8520 Smartphone
I was reseting the setting the settings on my blackberry z10 phone and it switched off when I'm switching it on it gives this message: www.bberror. com/bb10-0015 how do fix this problem, please help
Download and install the latest version of BlackBerry Link, visit www.blackberry.com/blackberrylink .
Windows
  1. Connect the device to the computer with the USB cable.
  2. Under the Devices heading, click the device name when it is displayed.
    Note: If the device is not detected, at the top-right click Preferences.
  3. Under Reload Device Software, click Reload.
  4. Click OK.
  5. Open BlackBerry Link.
Mac.
  • Connect the device to the computer with the USB cable.
  • In the menu bar at the top-left of the screen, click BlackBerry Link > Preferences.
  • Under the Reload tab, click Reload.
  • Open BlackBerry Link. Connect the device to the computer with the USB cable. In the menu bar at the top-left of the screen, click BlackBerry Link > Preferences. Under the Reload tab, click Reload.
    Apr 07, 2015 | Blackberry Cell Phones
    Issues charging using USB and Computer
    solution is to install only USB driver, so that PC recognizes the Blackberry correctly, and can also charge the device accordingly.
    Try and download usb driver for windows xp or windows vista
    Jul 19, 2010 | RIM BlackBerry Storm 9530 Smartphone
    Well my blackberry keyboard was off so when i tried to input my password it was wrong so now all that appears on my screen is th JVM Error 513 what do i do? i am manager and need my phone fixed asap please...
    First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
    Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
    Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
    If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
    Jan 10, 2010 | RIM BlackBerry 8800
    I need my blackberry 8800 unlocked
    i have a at&t blackberry 8800 I need the code for unlock the sim card
    Aug 02, 2009 | RIM BlackBerry 8800
    Blackberry 8800 will not charge on wall charger
    You need to find out if the problem is with your current AV charger - the battery or the phone.
    Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
    May 21, 2009 | RIM BlackBerry 8800
    My PC doesn't acknowledge my blackberry storm is connected. Blackberry Desktop Manager works, but nothing else does eg. Rhapsody, Windows Media Player 11. When it's connected it doesn't show in "My...
    You have to isolate the problem. Please follow the steps below:
    1. Connect the Blackberry into different USB port of the computer.
    2. Try connecting the phone in to different computer to test if there's really a problem with the phone.
    3. Try using different USB cable for the phone.
    4. Check the user manual to see if you need to set it as "Mass Storage Device" before connecting it to the computer.
    Otherwise, you need to consult the phone manufacturer for some advise.
    Have a great day!
    May 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
    Logging onto my personal IP address
    "HTTP Error 403 Forbidden" indicates a server permission error. You need to allow either anon access to the IP camera. You can probably do this using a local PC connected to the SAME subnetted network that your IP Camera is on.
    Jul 17, 2008 | RIM BlackBerry 8800 Smartphone
    Need help
    you will have to install blackberry desktop manager in order to route enough sufficient power to your blackberry device. you can download that software from the CD rom that came with your phone or by going to the following link:
    http://na.blackberry.com/eng/services/desktop/
    as soon as you download that software go to options, connection settings and change the connection type from NONE to USB PIN: ^^^^^^^ and it will charge just fine! :)
    Apr 20, 2008 | RIM BlackBerry 8800
    RIM BlackBerry 8800 Logo
    1,261 people viewed this question
    Top RIM Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    ismael castillo
    David
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
