Question about NorStar Lands Phones
How to connect norelco NTL800 PAGING INTERFACE MODULE TO NORSTAR 3X8 To provide night service ringing over paging speaker.
2 Suggested Answers
ynotphone
  • 192 Answers
SOURCE: Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Posted on Mar 20, 2009
Display Message
This only shows on the operator extension. It is there to notify you that a Night or Evening or some other service is turned on. You can press the LIST soft key to find out which service is in effect. You can cancel the service, but then you also cancel the purpose of the service like night ringing or directing some lines straight to voice mail. Feature #871 will cancel ringing service, #872 will cancel restrictions service, and #873 will cancel routing services.
Jun 11, 2013 | NorStar M7208 Corded Phone
T7316E - Phones just installed. None of them ring.
You need to ensure that the main bell is programmed to ring, also that the extensions are also programmed to ring as well. Also check that the ringer is switched on, on the base of the telephones. Also ensure your handsets to not go over the ren value permitted. Make sure the service is on the correct day service and not night service. Check that the handsets ring internally and ensure they are registered with the system. Ensure that the connections and wiring are also correct,
Mar 15, 2013 | NorStar T7316E Telephone
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
Norstar m7324 won't come off night ring
Is the button still programmed?
Do F871 in meantime....F#871 on older systems helps too or just F87.
Program button:
F*3
button
Feature
871
Jul 23, 2012 | NorStar M7324 Telephone
Our norstar m7310 phone will not accept incoming calls
Hi guys, i hope everything ok with you all, the reason i contacting with you is, im live in Tampa Florida by the Tampa International Airport and i do have my own company, but there is anyone who wants to throw away or wanted give it away for free the Norstar Phones M7310 M7324 T7316e and if you have also the Norstar systems 6x16 or 3x8 and doesn't wanted anymore at all because you buy a differents phones and systems or something happen you can donated to us and i can go personal and get it, please we just have 7 oldest M7310 since 1989 and 2 of them starting giving me problems, and i trying many different ways and making a lot phones calls, and there is no Technical Support can help me at all, please there is somebody who live in Tampa or near to Tampa can donated to us the Norstar telephones and the Norstar Systems 6x16 or 3x8 beside throw it away please, there is somebody available, no matter how is the Norstar Meridian telephones looks like and same with the Norstar systems if long is working fine and in good or better or perfect conditions we can accept that with all our heart. Thank you guys you can e-mail me at ivelyr@gmail.com please leave me your details and name and your phone number for i can contact to you right away, and your address in case its ok by you to stop by where you are, for we can met, i need your help, im so despair to resolve this situation. Thank you soooooooooo much in advance. my name is Noel Trinidad.
Thanks.
Sep 24, 2010 | NorStar Meridian M7310 Phone
Toggling between greeting 1 and greeting 2
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Mar 11, 2010 | NorStar M7310 Corded Phone
Auto Attendant
Answer Lines
1 – Feature 983
3 – Press AA
4 – Press LINES
Feb 11, 2009 | NorStar M7324 Telephone
Where can i find instructions for using features Norstar M7031
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 08, 2008 | NorStar M7310 Corded Phone
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 02, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
236 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
