Question about Kitchen Ranges
My pellet stove will start but the auger will not drop pellets. What should I do.
  • 962 Answers
You need to replace the auger motor. Go to fasco .com they may have one. Or enco.com I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Posted on Nov 20, 2008
  • softvar Mar 06, 2017
    Go to www.pelletstovemaster.www.pelletstovemaster.com
2 Suggested Answers
SOURCE: St Croix pellet stove: pellets drop
ignitior is bad ....
Posted on Mar 29, 2008
No flame. The auger works fine and the pellets are feeding in. There is no fire to burn them.
Do you have a user's manual? Most pellet stoves need to be lit before starting the auger to sustain the fire.
Feb 10, 2017 | Cars & Trucks
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
Jamming auger onmagnum countrysidepelletstove
The softwood pellets are not the problem. The problem is the quality of those pellets. Make sure you are not using last years fuel and it has not been stored outside. Also check the auger system for junk, gouging and bending of the auger.
Nov 26, 2013 | MagnuM Countryside Pedestal Corn Stove
Pellet stove augur starts and will start burning and then it back up pellets will not come out the augur will not spit out the pellets and they just get chared
auger may be jamming or motor is starting to go unplug unit and open back and oil auger motor and check operation- auger may not be sitting right in feeder tube also try a different pellet some pellets are bigger(sizes vary from company to company) which sometimes jam at feeder in hopper
Nov 26, 2009 | Ruud UBHC Air Conditioner
Kitchen Ranges Logo
922 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
