Question about RCA P56940 56" Rear Projection Television
Blurry picture I have an RCA P56940 rear projection tvwith a ctc195 chassis. I was given this tv and it would not power up,it only made a chirp noise when plugged in. I replaced the flybacktransformer and the horizontal chipper advice I received. The tv now powers on and works fine except thepicture is out of focus and there is a red, green, and blue stripevertical up the right side of the screen that takes up about 2 inches.I can see the picture that is displaying but smaller writing like a boxsaying no signal available is completely unreadable(with a hard look Ican see thats whats in the box). Hopefully someone could point me inthe right direction.
  • tim46714 May 11, 2010
    clean lenses on picture bulbs adjust projection
  • 119 Answers
SOURCE: 56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Posted on Jan 16, 2007
SOURCE: No picture or sound - TV makes chirping noise
The chirping sound is the power supply trying to come up, but can't due to a short or other condition. Open up the set and see if there is any obviously bad (burned) components.
Posted on Jun 27, 2007
SOURCE: RCA r56wh78 rear projection screen is blurry
I have the same model and the same problem - the picture just started getting slightly blurry, and moving objects get sort of grainy and jagged around the edges. I'd like to try the flyback adjustment you mention, but I have no idea what to look for. Is there a guide or reference that could help with this stuff? Schematics?
Posted on Oct 08, 2008
SOURCE: RCA 46 inch convergence problem
We have sound but no picture... Can this be fixed???
Posted on Feb 15, 2009
SOURCE: RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Posted on Nov 07, 2009
Rca rear projection broke?
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
Apr 02, 2009 | RCA P52921 52" Rear Projection Television
Bad focus
Yes after removing the back you will see tree transformers on the main board. it has three adjustment controlls on it ... the top one is focus. most of the time if you clean the lenses and mirror that will clear up fuzzy picture problem but some times the coolant is low or contaminated in the projection lenses
Nov 21, 2008 | RCA P56940 56" Rear Projection Television
No sound no picture
That is usually caused by the horizontal output cisrcuit or the flyback. Can you post the chassis number as RCA has to be diagnosed by chassis number.
Mar 29, 2008 | RCA P52937 52" Rear Projection Television
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
RCA P52940 Television
The P52940 uses the CTC195 series main chassis. The most common reason for the set not to start up is a shorted flyback (high voltage) transformer. The set actually does try to start, but the computer immediately detects the extra current drawn by the shorted flyback and instantly shuts the set back off. The chassis should be checked and the flyback replaced by a qualified tech familiar with RCA projection TV's.
Aug 12, 2007 | RCA P52940 52" Rear Projection Television
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Misconvergence
Convergence on RCA P56940 chassis PTK195 can only be done by service center with RCA Chipper Check computer interface box. Sounds like possibly missing -15 volt or +15 volt supply to digital convergence circuit, bad i.c.'s U19503 or U19504. Supply voltages come from regulator supply transformer T19701 diodes CR19707 (-15 volts) and CR19709 (+15 volt)
Dec 22, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
