Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Will Not Spin
Kenmore Heavy Duty 70 Series, water will drain, but will not spin, any ideas?
I don't want to take it appart - how much do you think for repair?
Do I need a motor, or a belt or just buy a new one.?
  • 370 Answers
IT actually is called a drve coupler. This brand of washer doesnt have a belt. The part is only like 30 bucks at the most. My shop sells them for 28. This is a great washer! If you dont want to take it apart just call a service tech. The bill shouldnt be that much. Dont let them try to sell you something you dont need. A lot of techs tell people its the transmission to get more money. You just need a drive coupler. The part number is 285753A.
Posted on Nov 21, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty series 70 won't spin
Will it drain ? IF wont drain either , then the lid switch is bad . (The piece on the washer where the lid actuator goes into the washer top ) . If it will drain , then the motor/trans coupling is bad , if it will not agitate/spin .
Jul 22, 2009 | Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
213 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
