I have a TLP 2742 tag printer, it was working fine with my old computer but now I have replaced all the info. And this printer with new computer and now it’s not working. I have installed the software through internet; I played around with it before installing the printer with the new pc. I have installed the printer but now when I send the job to printer its only print out blank tag and sometimes its only prints out left side of the tag. I have tried resetting the print putting in Dump mode but no solution... I’m afraid if I changed some setting by mistake on the software/driver …Please help!!!
when i try to print the job shows up momentarily in que, lists pages as n/a, and then deletes...
(More)
when i try to print the job shows up momentarily in que, lists pages as n/a, and then deletes iteself
I have 4 Zebra TLP 2844-Z printers, 2 have HW version V13.0.0.42, 2 have HW version V18.0.0.42. I...
(More)
I have 4 Zebra TLP 2844-Z printers, 2 have HW version V13.0.0.42, 2 have HW version V18.0.0.42. I upgraded the firmware to V45.11.7z of the 2 printers at V18 with no problem. However, after flashing the 2 printers at V13 using Zdownloader V2.0.6 (and powering off/on), the fw version is unchanged. I have tried both over the network and with serial connection, the Zdownloader shows the upload progresses just fine. When uploading using the serial connection, the status LED blinks green, when using the network connection it is solid green (I take it this is normal). My current FW version is V45.11.2a. The printers appear to function normally, I can point my browser to their IP address and change the configuration/settings, and I can send commands to them using the setup utility and I get a response back from a status inquiry for example. Any suggestions would be helpful. Thanks!
how can I retreive to my computer a form from a Zebra tlp-2642 printer. I want to put it on another...
(More)
how can I retreive to my computer a form from a Zebra tlp-2642 printer. I want to put it on another printer
Please advise how to print to zebra tlp 2844 which connected via usb port using visual basic 6...
(More)
Please advise how to print to zebra tlp 2844 which connected via usb port using visual basic 6 or visual foxpro 9.
Sample codes will be very much appreciated
I have a Zebra TLP2844 using 80x30 labels but when I try 2 design my label to fit the size I get a...
(More)
I have a Zebra TLP2844 using 80x30 labels but when I try 2 design my label to fit the size I get a pop up message saying printer does not support user defined labels. If I put the same printer on a diffrent PC I can get to define the label. Please assist.
