Question about Pentax Optio S5i Digital Camera
S5i won't turn on in Capture mode
When I press the power switch, the camera gives FOUR rapid beeps and does not turn on. If I press Playback at the same time, it will turn on and I can view the card. But as soon as I press Playback again to try and enter Capture mode, it turns off. The camera has not suffered damage and the battery is full. Any suggestions?
I also had this same problem. It wouldn't turn on so I figured I had nothing to lose by taking it apart. It is very difficult to get to the battery, and once i found it, I managed to remove the battery. I could not manage to soder on a new battery, so now there is no button cell battery in the camera. It now works fine, but every time I change the battery I have to reset the date and time. It beats buying a new camera though.
Posted on Aug 01, 2007
Hi Aunty Edna. I had exactly the same problem with my S5I 4 weeks ago. Went out and bought another camera then decided had nothing to lose by doing heart segury on S5I. Found it has a watch battery soldered to board under memmory card holder which was flat. I replaced that with a similar battery and it fixed the problem. Its not an easy job but if you know someone good with there hands it would take about an hour.Hope this helps. Regards Andy
Posted on Dec 23, 2006
How to make a digital copy
o do this:
Press the power switch. (Capture mode)
Press the Play button. (Playback mode)
Press the four-way controller (down). (Playback mode palette)
Press the four-way controller (right) 3 times to select [Image/Sound Copy].
Press the OK button to display the screen for selecting the copy destination.
Press the OK button to copy the data.
Press the Play button or press the shutter release button down halfway to return to Capture mode.
Playback Mode Palette Copy destination selection
* This function can only be selected when an SD (SDHC) Memory Card has been inserted in the camera.
Jun 11, 2012 | Sylvania Hd1z Sdsdhcmmc 720p Hd Pocket...
How do i move the pictures from the camera memory to the sd card
While in Playback mode, press the MENU button. Use the cursor keys to select "Copy image & sound" and press cursor-right.
Full instructions are in the "Copying Files" section of the manual (page 116 in my copy) If you need a copy, you can download one from the manufacturer's web site at
http://www.pentaximaging.com/files/manual/OptioS5i_Web.pdf
Sep 03, 2011 | Pentax Optio S5i Digital Camera
On the vivicam 7022 how do u view the pics u take?
When you turn on the camera, it's in Photo Capture mode. Press the MODE button twice to enter the Playback mode. You can press LEFT/RIGHT to scroll through the images. Pressing T will zoom in, while W will zoom out.
It's all on page 29 of the manual.
Apr 02, 2011 | Cameras
How you can eliminate the sign on E:61:00 the camera sony DSC T-5 series Cybershot
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks and Keep using Fixya
Mar 11, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
E:61:00 on sony cybershot camera
To solve this
Mar 02, 2011 | Sony Cyber-Shot DSC-F828 Digital Camera
How can I access the photos in the camera memory? Is there a way to copy them to the memory card?
Press the MENU button in Playback mode. Use the four-way controller to select [Copy image & sound]. Press right on the four-way controller. Use the four-way controller to select "Camera to SD" and press the OK button. All files are copied to the SD card.
Nov 17, 2010 | Pentax Optio S5i Digital Camera
I took pictures, and the camera instead of recording them to the chip, recorded them to the camera memory. I don't have special cord from the camera port to USB to retrieve the picture to the computer....
Go into playback mode. In the camera menu is an entry for copy image. It gives you the option to copy the contents of the internal memory to a memory card.
Sep 08, 2010 | Pentax Optio S5i Digital Camera
How do i remove the green mode from my pentax e40
If you press the green button again it cancels green mode.
If you want to select a different mode press the down arrow on the four way controller when you are in capture mode.
That has icons for different modes like landscape or program mode.
Move to the icon you want by using the 4 way controller then press ok.
The button with a triangle on it that is above the 4 way controller switches between playback and capture modes.
Jan 30, 2010 | Pentax Optio E40 Digital Camera
Cannot find batteries that work. I have replaced the batteries with different brands and it still wont turn on. What is the problem.... Its not reliable.
It is possible that there is a small amount of corrosion on the contacts in the camera. Use the eraser end of a common pencil to clean these contacts. Also, make sure you are using the correct batteries. It shows here that you have the polaroid i830. this camera uses two AA batteries: Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the two AA batteries into the battery bay. Install the SD card into the slot located next to the battery bay. Close the battery door.
  1. Step2Press the power button located on top of the camera. Locate the "Playback" button on the rear of the camera, under the "W" button; this button switches the camera between "Capture" and "Playback" modes. Set the camera to "Capture" mode.
  2. Step3Press the button on the bottom right of the rear of the camera to open the mode selection window. Use the navigation buttons to select "Still Image" mode. Press the button labeled "Set Disp" to confirm your selection.
Nov 02, 2009 | Polaroid i830 Digital Camera
Symbol of a lock
I had the same problem - try this. Switch to playback mode by hitting the play button. In playback mode try the menu button (It worked for me). In the settings scroll down to the reset option and reset all camera settings.
Hope this works for you
Dec 11, 2007 | Pentax Optio S5i Digital Camera
Pentax Optio S5i Digital Camera Logo
237 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
