Question about Acer Computers & Internet
Unable to start
The system do not start and makes some beeps
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    What is the beep pattern... for example 3 long beeps and 1 short beep.
    These beep patterns tell you where to look for the problem.
    Novelist:
    Scholar:
  • 85 Answers
Depending on the type of bios that you have
You might find the information on this page to be helpfull: http://www.computerhope.com/beep.htm
I hope this helps (if not then let me know and i have a more detailed list somewhere here that I can dig out for you)
Posted on Nov 20, 2008
AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Computers & Internet
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Hp pavillion dv2700 is not starting, 3 beeps, 1 long and 2 short
That is some sort of video failure. "Unable to initialize video (to display the post code)"
Dec 31, 2013 | HP Pavilion dv2000t Notebook
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Beeps 4 times
The beeps are from the power on self test which makes sure all hardware is working before starting the boot process. It would help to know the make of the computer but 4 beeps means system timer failure. System timer failure can be from many things need the make to help more.
Oct 04, 2012 | Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
CONSTANT BEEPING/UNABLE TO USE SYSTEM
try 123, 1234, 12345, or 123456
also one of these might work, 321, 4321, 54321, 654321
Sep 21, 2009 | GE Security Simon 3 Wireless Home Security...
The motherboard makes a 3 second beep over and over.
Nick,
That beep code usually signifies one of the devices connected to your motherboard is having an issue and the motherboard is not able to past the POST.
You will have to do some digging to determine the cause of the problem. First step, remove the RAM, and see if the error code changes.
How did the bracket brake? If it is broken your CPU or CPU Socket might have gone bad.
If you're thinking about upgrading, you might as well ditch the PC2700-3200 and upgrade to DDR2 or DDR3. PC2700 is DDR which is becoming a phased out product line. Just FYI.
Hope this helps.
As a reminder, if this post helps, please rate it. Thankyou.
Feb 27, 2009 | ASUS P4S533-X Motherboard
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Computers & Internet Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
