Question about Altec Lansing AVS 300 Computer Speakers
What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
I have lost my Altec Lansing AVS300 Speaker power adaptor, please help me to find or build a new one.
  • 4 Answers
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
  • Muhammad Fuady
    Muhammad Fuady Jan 31, 2015
    what is the suitable plug size? Is it 5.5mm x 2.5 mm? or 5.5mm x 2.1 mm
Power supply out put rating ? lost the original power adaptor that came with system acs340. trying to use a substitute
what is an acs340 ?
Is it a Altec Lansing subwoofer speaker for a computer
google search a4432 altec
13V 4A DC
If you decide to buy one check the input AC voltage matches your power outlet supply voltage 120Volt AC 60 hZ or
is it 240V 50
Hz - get it wrong and smoke may escape from the power adapter after the big blue flash occurs.
https://www.ebay.com/p/Genuine-OEM-Altec-Lansing-A4432-ACS340-Subwoofer-Power-Supply-13v-4a-AC-Adapter/664023647
Feb 11, 2018 | Power Computers & Internet
Can someone help with the DC Volt, amperage and polarity of Altec Lansing 120i speakers please. I lost mine. Thanks.
Polarity and V are usually indicated somewhere near the plug. If not open the one with the plug, look at the wires connected to it, usually black and red, if still not clear follow one of the wires to the first connection point, if its to an electrolytic cap, the caps polarity will tell you what the polarity is at that input, the plug will be the same. The amperage really doesn't matter unless its too low, it can be much higher then rated, since trahsformers are self regulating for amperage.
Aug 07, 2014 | Altec Lansing 120i Computer Speakers
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
I'm trying to hook up an Altec Lansing computer speaker system. I can't get the speakers to work. I'm use to speakers having a plug that fits the little green speaker outlet, this seems to...
You need to get one of these or something like it :
http://www.google.com/products/catalog?hl=en&biw=1024&bih=649&q=rca+to+mini+adapter&um=1&ie=UTF-8&tbm=shop&cid=15600543032554495997&sa=X&ei=2v89Tr_lCqjYiAL69aXDBg&ved=0CD4Q8wIwAw
it is a called a Mini/Rca Adaptor
Please Rate my Advise if it is helpful.
Aug 07, 2011 | Altec Lansing Multimedia Computer Speakers
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing VS4121, New Speakers, No Sound
If the speakers are brand new it makes me wonder how you know they worked fine in the States? I am also wondering how they were transported due to them probably being intolerant to extremes of temperature/humidity and probably vibration.
I am also wondering if you are using the correct supply voltage and type of supply.
If you are using the power adaptor supplied for use in the USA, it would probably be incompatible with your supply even though you are using a transformer.
If you are certain the speakers are in good order I suggest you obtain a power adaptor designed for your 220 volt 50Hz supply. I have browsed a little and cannot find a note of the power requirements for the integrated amplifier but this is presumably marked on the adaptor, the speaker or in the manual and so the power adaptor could be checked on and off load with a suitable voltmeter. I would be surprised to learn the supply is adequate
Apr 01, 2017 | Altec Lansing VS4121 Speaker
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Altec Lansing AVS 300 Computer Speakers Logo
1,086 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
