Question about Cameras
Bulb & change proceedure for a telex caramate 3200
    Genius:
  • 1,847 Answers
Plz you describe the issue in detail
Posted on Nov 20, 2008
  • Legin Varghese
    Legin Varghese Nov 20, 2008
    i think you want to replace the lamp.... check this link it will help
    http://www.youtube.com/watch?v=Y6fTxkjBR...
    thanks...kevin
I just got a used Telex Caramate 4000 slide projector but no manual. Who has one I can buy?
sadly when buying used items getting a manual would be the first thing I would ask about from the seller .. you can try searching thru Google and hope for the best
Jun 07, 2016 | Office Equipment & Supplies
How do i change the front turn signal buld in a 1990 buick riveria
I believe you can replace by laying UNDER the fender and reaching up . The bulb will twist to unlock. Replace the bulb and repeat proceedure. NOTE!!! you may need to remove some of your plastic splashguards to access it!!
Mar 28, 2014 | 1990 Buick Riviera
Want to transfer slide pictures from a Telex Caramate 4000 to a laptop. Is it possible to do this?
you need telecine transfer facility take it to duplication house they might help ypu
Dec 21, 2013 | Telex Caramate 4000 Used Audio Visual
Projector turns itself off and on
Caramates have a Thermal Breaker built into their electrical circuits, which will "open" if the internal temperature gets too high for safety. When the internal temperature drops to an acceptable level, the breaker "re-sets" and the projector will come back on. You will need to check for any obstructions to air flow first. Next, make sure the exhaust fan is running at the proper speed. Once those items are checked, if the problem still exists, you will need to locate a circuit diagram and the appropriate thermal breaker for replacement. Good Luck!! Jim
Oct 27, 2013 | Kodak Office Equipment & Supplies
Need to change rear brake light bulb on a 2000_L sedan. Owners manual addresses only the turn signal bulb change proceedure. The brake light fixture is flat not round.
there is an access cover in the trunk.Open that and just pull the bulb fixture out replace the bulb and place back in the hole.
Apr 07, 2012 | Saturn Cars & Trucks
I have an OLD telex projector. Looks like a box with a tv screen on one side and carousel on top. have no idea how to use it. maybe bulb needs replacing
Telex called those "CaraMate XXXX" (XXXX usually relating to model number ). The old ones projected on the internal screen. Newer models could project both on the internal screen and (by sliding a door on the top panel) on a projection screen for larger audiences.
If it needs a lamp, check with: www.bulbman.com But you may have to search - - it's been a long time since they were manufactured!
Good Luck !!
Jun 21, 2011 | Telex Office Equipment & Supplies
Telex 56 to cobra 4 pin
Hi there!!
the yellw wire is not used on the microphone conector most of them are just cut and left in there loose as long as its not shorting out on anything!! The wiring for the telex 56 for your radio Cobra 29 LTD is as follows: PIN #1 Shield & Red, PIN #2 White, PIN #3 Blue, PIN #4 Black, Yellow wire not connected!!
If you notice when you have the connector apart on the back of the pins where the wires get soldered to the pins are numbered so you will know which pins they are or on the front side of the connector the pins are also marked wich numbers they are!! If you have any other questions please feel free to e-mail us at: bigdscbshop@hughes.net
Apr 18, 2009 | Telex M-560 Consumer Microphone
Replacement of headlights bulbs
1] remove th headlight assy. by removing the bolt on top of the assy and the 2 rod retainers.
2 ] remove the electrical connector from the headlamp bulb cover
3] rotate the bulb cover counterclockwise and remove cover
4] disconect the bulb connector
5] rotate bulb retainer counterclockwise and remove th ring
6] remove the bulb using a slight rocking motion
7] reverse proceedure to install
Feb 22, 2009 | 2005 Ford Taurus
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
