Sticky label I posted a request on the bulletin board for information on romoving a sticky label. The typewriter is a Brother AX325.
    Habit-Forming:
    New Friend:
  • 13 Answers
As long as it is adhesive sticky problem, use any oil base product or WD40 to clean it off than wipe down with a clean cloth will do. Home
Posted on Dec 10, 2015
    Scholar:
  • 183 Answers
I assume the label is stuck under the platen
the easiest way is to get a rag, wider than the label, dampen it with some solvent, and try to roll it in like a piece of paper. don't use too much solvent, or it will run off into the machine. be careful, it may melt the plastic.
to see if you have a good solvent, stick a label on something it won't hurt, put a little solvent on the label, wait a little bit and see if the label comes off easily.
if you're not careful, you can damage the machine.
or take the machine to a repair shop, the platen is not easy to remove
Posted on Nov 22, 2008
My elderly neighbour has a sticky label stuck behind the paper roller and I don't seem to be able to life up the front of the typewriter to be able to clear it.
Depending on the typewriter model, most all have release points located on either end of the roller bar. Locate these, push forward or backward, release roller bar and lift the bar out. This would be the preferred solution, as it would make removing the sticky note far easier. These release points will look like small levers and should have directional arrows visible to indicate which directions they should be pushed to release the bar. If you cannot remove the roller bar, I suggest standing over the typewriter and use a pair of tweezers to remove the sticky note. It may take some patience, and may tear, but eventually it should be able to be removed,even if it is bit by bit. Also, with each portion removed, turn the roller bar to make the remaining part of the note more visible. Good luck.
Jan 11, 2016 | Brother AX-100 COMPACT TYPEWRITER
Sticky i key
Sticky isn't a really good description but i'll guess that you mean that you have to press it hard.
Under each key is a foam pad that makes contact. The foam gets old and crumbles, the pads can be replaced but generally not by the user.
DickyO
Mar 07, 2011 | Brother EM-430 Typewriter
How do I take apart my Brother typewriter to remove a label stuck to the metal bar where the paper feeds in?
I wish I had one in front of me, but I don't. Brother used two ways of holding the Platen (big black roller in place. Open the top cover and look at the frame where the platen is held. You will likely see plastic clips holding the axial that runs through the platen (85% of brother machines have clips), or you will see that the axial runs directly through the frame. If you see clips just squeeze the tabs and lift up. Note which side has the gear, so that it is reinstalled the same way. If you don't have clips you will need to loosen the Allen screws holding the knob to the platen roller, and the roller will lift right out. If the label left any of the rollers sticky they must be completely cleaned before reassembly, Goo-Gone is a good product to remove gummy labels.
Best of luck, Ron
Jan 06, 2011 | Brother ML-100 Typewriter
How to install correction tape in the GX-6500 Typewriter?
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
GL
Jul 04, 2009 | Brother Office Equipment & Supplies
Manual for brother electronic typewriter AX325
You can get the user manual here for 42 cents.
http://www.brother-usa.com/accessories/Accessories.aspx?Model=AX325&ACASCID=54
Apr 21, 2009 | Brother Office Equipment & Supplies
Correction ribbon blocks type on brother
Be sure you have a dry L/O tape (Gen. Ribbon t 355 or equiv.) if you have a sticky L/O tape it will give you all kinds of trouble.
DickyO
Apr 02, 2009 | Lexmark Wheelwriter 15 Series II...
Can't load paper on a brother EM-530
try using the paper release lever and putting the paper in it could be that a sticky lable is stuck in there
Dec 04, 2008 | Brother EM-530 Typewriter
Remove sticky label from paper guide
depends on what kind of machine, they are all a little different.
Nov 20, 2008 | Office Equipment & Supplies
HAVING TROUBLE PUTING IN THE CORRECTION TAPE
Make sure you are installing the tape with the sticky side facing the paper. I
May 05, 2008 | Brother ML-100 Typewriter
242 people viewed this question
jasbo
jasbo
