Wep key I bought a Linksys RangePlus Wireless Network Adapter and am trying to set it up to my Dell laptop 1525. It is asking for a WEP Key or passphrase. How do I get this?
  • 105 Answers
You need to remove the wep key from the linksys configuration
to enter the configuration of the router, in Iexplorer, go to http://192.168.1.1
there must be a security access confguration than refer to wep active/inactive
switch it off, it should go.
Posted on Nov 21, 2008
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
I want to set up my LINKSYS network adapter and my laptop asks for the pin number? where is the pin number?
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.
For information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 28, 2011 | Linksys WUSB11 802.11b Wireless Adapter
What is a WEP key for a Linksys WRT400N wireless router?
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Linksys WRT400N Router
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Were would i find the wep key or the wpa for the WUSB54GSC Wireless -G USB Network Adapter/
The Wep Key is located in the wireless router settings and will not be found on the network adapter. The network adapter needs the wep or wpa key to connect to the wireless router. You will need to use a computer hooked up directly to the router and enter the router settings menu to find or change the wep or wpa key. Most routers use 192.168.0.1 or 192.168.1.1 to enter the router menu. When you input the IP address above a screen should come up asking for a username and password. Enter those and that will allow you to get into the router menu. If you do not know the username and password you can reset the router with the reset button and that will restore the default password which is usually no username and password is admin.
Oct 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Cannot get on the internet
Hi
The problem was in the wep key. I entered the old wep key, not recalling that we had to trade our router in for a new one last summer. When I entered the new wep key we were able to get online.
thanks again
Apr 09, 2009 | Linksys Rangeplus Wireless Pc Adapter
I am needing the key or WEP to re-connect to wireless
If it was not setup with a WEP key then try "admin" that is the password for Linksys when not set up. The purpose of the WEP key is to install a password to type in before anyone can use your network. So if "admin" does not work then you have to ask the person who set up the Wireless Network what the WEP key is.
Jan 02, 2009 | Computers & Internet
Wireless connection with work laptop
have a look at the book that came with the wireless router and see what is the ip address. it should be 198.162.1.254. type this into your home pc internet explorer address bar. you should get the router settings page. then go to the wireless setup page and you will find the wep key there
Apr 21, 2008 | Dell Latitude D610 Notebook
Linksys Wireless-B Router, Model BEFW11S4
It's really easy to find your wep key if you can log into the router page.  Usually the router is defaulted to 192.168.0.1 or 192.168.1.1
You put that number after the http:// in a web browser and it should ask you for a username and password.  Either enter the username and password you set it up for, or if you didn't set one it's probably admin admin.  Now there should be a page with a bunch of settings.  Near the top click on the tab that say wireless, and under that tab there should be something called security.  The WEP key you have set up should be in here.  The WEP key is not the passcode, just wanted to point that out.  It's most likely under something by the name of key 1 or something to that affect.  That should take care of your WEP key problem.  I would personally recommend upgrading to a wireless G router if the other devices on your network can use G.  Wireless G is much faster and also allows the use of wireless B devices on it.  Hope I helped.  If you need more help just ask, I might be able to get some screenshots up or direct you to a manual.
Oct 17, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
