Remove sticky label from paper guide
I have a sticky label on the metal paper guide under the roller. I have removed the two screwsfrom the top and release the clips on the sides but cannot get the top off. Is the something else that holds it. Icannot see any thing obvious.
    Scholar:
  • 183 Answers
Depends on what kind of machine, they are all a little different.
Posted on Nov 22, 2008
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
My elderly neighbour has a sticky label stuck behind the paper roller and I don't seem to be able to life up the front of the typewriter to be able to clear it.
Depending on the typewriter model, most all have release points located on either end of the roller bar. Locate these, push forward or backward, release roller bar and lift the bar out. This would be the preferred solution, as it would make removing the sticky note far easier. These release points will look like small levers and should have directional arrows visible to indicate which directions they should be pushed to release the bar. If you cannot remove the roller bar, I suggest standing over the typewriter and use a pair of tweezers to remove the sticky note. It may take some patience, and may tear, but eventually it should be able to be removed,even if it is bit by bit. Also, with each portion removed, turn the roller bar to make the remaining part of the note more visible. Good luck.
Jan 11, 2016 | Brother AX-100 COMPACT TYPEWRITER
HP LaserJet Pro 300 M375nw keeps saying paper jam in drawer 2 but there is no paper anywhere.
My problem was the rollers at the top of the printer where the paper feeds out of the unit. I had printed some labels and some sticky material from the labels stuck to the rollers and metal fuser unit. I cleaned off the sticky strips from the rollers and fuser roller and the unit works fine now. You may have to let the printer cycle several times so it turns the rollers so you are sure to remove all the sticky stuff or paper. I also used a can of the compressed gas to spray out all the dust, paper and sticky stuff after I scrapped off with envelope opener.
Jul 24, 2012 | HP LaserJet Pro 300 M375nw All-in-One...
Paper misfeed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Dec 19, 2011 | Copystar Office Equipment & Supplies
Paper is not feed
Nov 28, 2011 | HP Office Equipment & Supplies
I cant get the paper to feed without jaming is ther a way to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
How do I take apart my Brother typewriter to remove a label stuck to the metal bar where the paper feeds in?
I wish I had one in front of me, but I don't. Brother used two ways of holding the Platen (big black roller in place. Open the top cover and look at the frame where the platen is held. You will likely see plastic clips holding the axial that runs through the platen (85% of brother machines have clips), or you will see that the axial runs directly through the frame. If you see clips just squeeze the tabs and lift up. Note which side has the gear, so that it is reinstalled the same way. If you don't have clips you will need to loosen the Allen screws holding the knob to the platen roller, and the roller will lift right out. If the label left any of the rollers sticky they must be completely cleaned before reassembly, Goo-Gone is a good product to remove gummy labels.
Best of luck, Ron
Jan 06, 2011 | Brother ML-100 Typewriter
We have a dymo labewriter that has a label jammed in the roller. Part of the sticky part is stuck on the roller. Cannot be pulled through. What to do?
LabelWriter Label Jam
  1. Unplug your LabelWriter.
  2. Remove the spool and labels.
  3. Remove the face plate.
    • Note: The face plate is the piece with the DYMO name/logo.
  4. Using the paper release lever on the left side of the printer, move the print head away from the feed mechanism.
  5. Straighten out a paper clip and GENTLY cut away at the label caught in the printer.
  6. Using caution, begin removing the label.
    • Note: We recommend using tweezers to remove the jammed label.
  7. Reinsert the face plate back on the LabelWriter. If you need assistance reinserting the face plate:
https://dymo.custhelp.com/app/answers/detail/a_id/278/session/L2F2LzEvc2lkL2ZVOGZXRmlr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | Dymo Office Equipment & Supplies
My samsung ml-1430 won't feed paper
There is a solenoid on the board of your printer. It pulls in the metal tab that allows that pickup roller to spin. It is supposed to let the roller roll once, but if it gets dirty, it gets sticky,and this might be the problem you are facing.
Here is the solution to the problem;
Take the board off of your printer and push in the tab. If it sticks for any longer than 1/4 of a second, then get a small flat-head screwdriver and remove the foam padding on the solenoid. Make sure you get it all. After that, get a piece of paper, fold it in half, and smash it in between the solenoid and the tab. Then slowly remove the paper, while still holding the tab. Do this until all the sticky stuff comes off on the paper. This should fix the stickiness, and allow the tab to go back out.
Thanks and take care.
Jun 29, 2010 | Samsung ML 1430 Laser Printer
182 people viewed this question
k24674
