Question about Polaroid 15'' HDTV Monitor FLM-1511
Video screen will not stay on
I have to turn the power off and back on several times before the video screen will stay on. The audio continues to work each time but the screen goes black. At first it would stay on after 3 to 4 tries, Now it is taking about 30 cycles before the video will stay on. I cant take it any more. Is it worth looking for a repair location, is this a problem that other people are having. Is this just a power supply problem?
  • stuart647 Nov 20, 2008
    O am using it as a tv so the input is still working, but just goes black. If I turn it of and then back on the picture will stay for about 5 seconds and goes black. Dont know why I have kept turning it of and back on this long, bet it has taken more times to get it to stay on. Once on it will work all day.
  • Tyler Bustinza May 11, 2010
    When you lose the picture, does your screen say "No Input Found" or something to that effect, possibly image or text that tells you that the monitor is still functional? This text only has to be on the screen for a fraction of a second to better diagnose the issue. Or is the screen completely black without any sign of ever turning on, other than the audio playing?
I have a question does this apply to my polaroid 1511 tlxb and its doing the same thing, i opened it up exactly how you said to and i have the power suply board out and i am looking for the 1000uf 16v and i cant find it, and i dont understand about it being bulged and there are none that i can see burnt at all,, any help here would be helpful becouse i opened it all up and a regular tv guy would be upset if i carried it in in this condition, thank you
Posted on Jan 20, 2010
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
2 Suggested Answers
  • 71 Answers
SOURCE: Polaroid 15
Do you have to turn it back on with the remote after this?
If so, then you may have set a timer by accident through the menu system.
More information would be required.
Posted on Aug 04, 2009
My screen turns off and on... stays off for several seconds and thens turns back on... does this several times, then wont turn back on until I unplug the power cord and replug.??? Unit is about 1.5 yrs...
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Jan 20, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
May 19, 2009 | Marantz SR5500 Receiver
JVC GZ-MG37U Menu screen won't come on, blue access lt. stays on
you have to check the firewire securety port....
it protect the camera from the wrong conections with the pc...
it doesn"t complot the camera work....
if you have a playback recorder deck it can wait ....
Jan 21, 2009 | Video Cameras
PRO 510HD PROBLEMS
if you know anything about the tv, take off the back and remove the power supply board. Reflow or resolder the solder points, takes like 2 hours, but is well worth it as my tv works fine now. make sure to use rosin core solder and good luck
Sep 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Polaroid 15'' HDTV Monitor FLM-1511 Logo
239 people viewed this question
Top Polaroid Computers & Internet Experts
micky dee
Tom Chichester
Steve P
Steve P
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
