Question about Philips Magnavox 51MP392H Rear Projection Television
Dark screen My Philips rear projection appears to be getting darker, is it because it requires cleaning or is the lamp going bad? It appears that it has happened over night, and I should mentioned that a kerosene heater is in the same room. Which would lead me more to cleaning, and another question is where can I download another manual, I haven't been able to find mine.
  • 33 Answers
If you take the back of the TV off like 4-6 screws star head/shape style, you can clean the lenses and there is a BIG mirror if you stick your head in then turn it around like in the excorsist you will see the mirror (sorry only way I could think of explaining it
I'll attach my general message there is a link to the service manual in it.
NOTE: I did read somthing in the manual about what NOT to clean the lenses with and how to clean them I don't remember so be sure to read it they might have some sore of coating?? just do a word search in the manual.
I found this in my manual however I would look at the link to be sure in your manual:
2c) Using denatured alcohol on a cloth made of 100% cotton or a lens cleaning tissue, gently clean the C element (fisheye) lens, coupler and the CRT faceplate. and allow to fully dry.
Caution: Do not use soap or detergent type substances to clean the coupler and its related assemblies.
I remember as a kid those heaters putting out a lot of residue, so good luck, however I fear your problem may be in your expensive lamps, and these TV's are not that relaible...
Generic informational Post
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
Where I got all my parts that worked:
Suburban Electronics
Manual Library you should find all you need here:
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with.
Posted on Nov 20, 2008
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
very possible unit has bad optical engine .May not be worth repairing.Optical engine is complete unit that includes lamp,LCD panels, fans,optics and other parts.They come complete and cost about 3-6 hundred dollars ..thanks
Jul 30, 2009 | LG 62SX4D 62" Television
.i have kdf-55wf655 my screen is get darker and
Well it could either be that your lamp is going out or that you have a weak ballast. This depends of certain things. If you haven't replaced the lamp, I recommend you do. If you already replaced the lampo and the image is still like this, it might be that your ballast is sending irregular voltgage, and that's why you get a dark image. discountdashmerchantdotcom
Jul 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
The lamp will dim as it ages and will do so quicker as it approaches end of life.  Do you know how many hours the lamp has been used.  How old is the TV?
May 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
Phillips cloudy screen
Crt coolant needs changing in the Blue and Gree CRTs red usually isnt affected.
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Rear projection TV (LG 44SZ51): Horizontal dark band on upper screen field
The LG 44SZ21RB Have a problem with their light tunnel collasping due to the heat from the lamp. They are available as a spare part @ LG and would also require some silicon adhesive to bond it into the assembly. Very tedious job for any technican (2-3 hrs). Lg will not release parts to the general public only to an authorised LG agent.
Mar 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
