Question about HP Jornada 820
Will not turn on
Resetting for 5+ sec did not bring the computer to life. Does the battery need to be installed for the 820 to turn on?
I have it connected to an Astron 12 volt power supply (16 amps) because the battery and cover are missing.
Larry Coblentz
SOURCE: Power Supply
Use HP D530 power supply to run SSF desktop which can run on 12v dC current. Just by using one 6000VA in series
Posted on Jan 03, 2008
  • 72 Answers
SOURCE: Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Posted on Dec 02, 2008
  • 370 Answers
SOURCE: HP notebook will not restart after closing cover overnight
Think it went into hibernation. Unplug from a/c adaptor, and remove the battery. Let it sit for 2 or 3 minutes, then plug in a/c adaptor and turn the unit on. It should reboot like new.
Posted on Mar 16, 2009
  • 3153 Answers
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Posted on Aug 11, 2009
  • 18 Answers
um what you want lol:?
Posted on Sep 07, 2009
Reset computer for cluster and wipers on 2000 sebring jx after battery dissconect
Try resetting the body computer,with key away from vehicle disconnect battery for 3 minutes then reconnect it and wait 30 seconds then switch lights on then switch ign on 5 secs later, sure worth a try
Aug 25, 2016 | 2000 Chrysler Sebring JXi
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Dec 06, 2011 | Panasonic Televison & Video
My dell latitude d 820 is not working, The screen is completly bank and only power on line blink.
press and hold the power button for 20 sec. the turn your computer back on. i think your computer is in sleep mode. otherwise your computer may have cracks in the solder connecting the ac power jack the the computer. try using a new battery and plug in your computer. goodluck
Mar 19, 2011 | Dell Latitude D820 Notebook
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Ways to increase laptop battery life
Let the thing drain completely down to nothing.  When the pop up window says you gotta plug the thing in, just ignore it and do your thing.  When the computer shuts off by itself, hold down the power button for 5-10 more secs to fully drain the thing.  Then plug your computer in and let the battery charge for a good 6-8 hours.  Then unplug the charger and let the battery sit and cool down for about 15 minutes.  This is called conditioning the battery and should be done once every other charge.  Also, its a good idea to turn off your wi-fi if your not using it, bring the brightness down on your screen, and close any non-essential applications that are running.  Cheers old chap.
Nov 21, 2009 | Televison & Video
My Photosmart E327 won't switch on.
Resetting the camera
If your camera does not respond when you press any
buttons, try resetting the camera as follows:
1. Turn off the camera.
2. If you have an optional memory card installed, remove it.
(Although removing an optional memory card is not
necessary for performing the reset, it eliminates the
memory card as a possible cause of the problem.)
3. Remove the batteries from the camera for 5 to 10
4. Reinsert the batteries and close the Battery/Memory card
5. After verifying that the camera works without an optional
memory card, turn off the camera and reinsert the card if
you have one.
Mar 03, 2009 | HP Photosmart E327 Digital Camera
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
HP Jornada 820 Logo
49 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
