Question about Pioneer VSX-815-K Receiver
Vsx-815 steady blinking blue light
So i acquired a pioneer vsx-815 ans when i plugged it in the power button started blinking a long steady irritating blue led just keeps pulsing at me in a mocking gist. no power will come on the display is inactive absolutely Nada. can anyone tell me whats wrong and how to fix it? thanks, josh
  • 5 more comments
  • PETER WAGNER Nov 29, 2007
    SAME PROBLEM..BLINKING BLUE LIGHT..POWER SUPPLY.IS IT A SIMPLE FIX?
    SAME PROBLEM.POWER SUPPLY.ANY SIMPLE FIX?
  • Anonymous Jan 04, 2008
    i have a steady blue blinking light
  • Mayday_FY Mar 23, 2008
    Same with a vsx-816
  • Anonymous May 25, 2008
    After a power outage in the area, my VSK-815-K reciever's stand by button is blinking and I've tried everything to get it to work. Any suggestions please??
  • levi_bakke Oct 20, 2008
    i have the same problem, but when I hold down enter and advanced surround, it resets but says there is an "amp err" Looks like i'm gonna have to take it in? So if I have to take it in, do you think it would be worth the repair, lets face it, it's still nice, but old news.
    Thanks,
    levi
  • Piet Van Zyl Nov 18, 2008
    I also have a Pioneer vsx-815s with the same blinking blue led problem. Please notify me if there is any solution offered.
Hold "Enter" and "Advnc. Surrnd" buttons on receiver at the same time.
Posted on Mar 16, 2008
  • 66 Answers
Remove the battery inside the receiver using soldering iron. then press the power button. it worked for me.
Posted on Jul 04, 2009
Thank you ! it worked! My husband and I open up the system ,located the battery. The battery is located (located looking at it from the front view) right front side. color black, size bigger then a dime but smaller then a quater. solder the bettery off , turned on th system. turned the system bck off and solder the battery back. worked like magic!
Posted on Sep 05, 2011
  • koprivaqi
    koprivaqi Jul 29, 2015
    please, any picture?
Outstanding fix rogzun
Posted on Sep 16, 2008
Pioneer support says it is a problem with the internal power supply components.
Posted on Feb 19, 2007
Pioneer manual repair
You have probably blown an internal fuse.
You may find more information here:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/218219098VSX815OperatingInstructions.pdf
If you are inexperienced in electronics repair,
you should take your unit to the nearest Pioneer service center.
Jul 21, 2014 | Pioneer VSX-815-K Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
The volume control button on the remote control does not work properly. Very hard to turn sound up or down. Have to push the button really hard. VSX-815-K
most used button on your controller could be a victim of grime carefully take apart the controller and gently clean the pickups with an eraser or light alcohol based cleaning solution a little goes along way also flip the button pad and inspect for dirt ok soft drinks are often the culprit hope this helps
Nov 17, 2010 | Pioneer VSX-815-K Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Doesn't turn on
does it have the blue flashing light on the power button?
Oct 02, 2009 | Pioneer VSX-815-K Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Jun 18, 2008 | Pioneer VSX-915 Receiver
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-815-K Receiver Logo
1,793 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
