Question about Garden
Coil flywheel air gapfor stihl 09 model
Also would like high and low speed carburetor jet settings
  • 181 Answers
Set the air gap at .011 to .012.inches,set carb high and low needles at 1 turn and 1 turne to start. after running it might take a minor adjustment to finish
Posted on Jan 12, 2009
    Sergeant:
  • 359 Answers
Set air gap with standard post card close enough , really
Posted on Dec 03, 2008
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Repair manual
Hi Robert:
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
Oct 03, 2013 | whipper snipper stihl fs 38
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Please take time to rate me
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Car settings stihl 026 with wt 194 carb?
Hi Alan Cowart
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
Wt 194 settings
Hi
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
Nedd to clean carburator out but i dont now what bolts to take out to do so it is a full case tear down,stihl 020av
all but throttle plate,completly take apart,soak parts in small container of clean gas and blow out all holes and ports of carb. body.with air compressor,before removal of high and low speed jets,turn in GENTLY AND RECORD HOW MANY TURNS clockwise to bottom eg:1+three quaters and three quaters of a turn.BE CAREFULL NOT TO TEAR GASKETS ON DISASEMBLY.
[lots of small parts]
Dec 04, 2009 | Oregon Scientific Complete Carburetor for...
Chain saw runs on full choke and a little on fast idle. Will not stay running, won't idle.
Sounds like a carburetor issue. Chain saws get the &**^% beat out of them during normal use.
This may just be a fuel jet adjustment if the carburetor has one. Sometimes there is a low speed jet and a separate high speed carburetor jet. Check for both. Also, check to see if the carburetor is loose - like I said, chain saws usually see some pretty rough service and things can loosen up.
If no joy on the above, you may need to clean the fuel tank, the fuels line, and the carburetor. This requires taking the carb apart so if you aren't familiar with this kind of work, take it to a shop.
Also, make sure the fuel mixture being put in the saw is correct
Mar 28, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
655 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
