Question about Microsoft HP Pavilion DV6276US Notebook PC
Computer turns on but freezes and doesnt load applications
The computer will turn on, but halfway through loading the start up applications it stops and if i try to click on anything, the computer freezes and the mouse turns into the wait thing. Also the background wallpaper clouds over after io try to click on anything. Any help would be greatly appreciated!
  • hdiddy Dec 13, 2008
    my computer turns on and i can click on one thing and then within seconds everything freezes and my pointer just turns into a wiating thing
  • chris2k7sear Jan 09, 2009
    i have the same problem, my laptop will boot and start but when its loading programs in the bottom right hand side of the screen it will freeze and crash.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Sounds like your computer is a old one, or is slow. The problem could be little RAM, which is what the computer calls speed and how fast it will open things, the CPU is too small, which is the main processing unit and causes slow speeds if it is not one of the latest CPUs or your Hard Drive is full and doesn't have enough free room to run anything well. Fist thing i want you to do is run a virus scanner to make sure you have n viruses causing the problem. if its all clear go into my computer, find the C Drive and right click on the icon and go into properties and check its free room. if its less than 250MB delete programs you don't use or don't need anymore. Now go into Start>All Programs>Accessories>System Tools and open Disk Defragmenter and Click on Defragment to begin the process. This will give you more free room and give it a small boost of speed in opening programs. This can take a very long time, talking hours so best to do it at night. A good way to boost your computers speed is to give it Virtual Memory, Which turns some of your hard drive into RAM. Right Click on My computer>Properties>Advanced and look for Performance and press 'Settings'>Advanced> and find Virtual memory and press change and click on the 'Custom size button' and Put '1024' into 'Initial size(MB) and put '2048' into 'Initial size(MB) and then click set then ok. It may ask you to reset your system. Do this. Now see if your application programs load faster. if not its a hardware problem and take it into a computer Technitian to get some more RAM in it to speed it up.
Hope This Helps
Posted on Nov 20, 2008
How to stop buffering
  • 1 Allow the movie to load completely, or at least halfway, before you start to watch it to stop video buffering.
  • 2 Start the movie and then hit stop until the movie has fully or halfway loaded. As the movie is loading, you should see a yellow or gray line. The line you see will get longer as it loads.
  • 3 Close all windows that you don't need. Having too many windows open will slow the loading process.
  • 4 Resume play once the movie is at least halfway loaded or fully loaded. By this time, you should be able to enjoy the movie without the video buffering or constant starting and stopping.
Jan 21, 2014 | Computers & Internet
Compaq presario v2000 freezing after start up. making it impossible to navigate pages to solve
click on start and then click on run.
type in MS config and then click ok.
uncheck the option which says load startup items.
Click on ok to restart the computer.
This should stop the computer from freezing once it turns on.
Apr 16, 2010 | HP Compaq Presario V2000 Notebook
My toshiba laptop will not load
Would suggest booting your system in Safe Mode and running anti-spyware (SpyBot) and anti-malware (Malwarebytes) software. Hope this helps.
Jul 12, 2009 | Toshiba Satellite A60 Notebook
Gateway laptop computer freezes during system recovery
Turn the computer off, then start it back up and press the f2 key repeatedly til a blue screen called the BIOS screen comes up, press the right arrow on your keyboard so it goes to the advanced tab. go down to speedstop and disable it, press f10 to save changes and start computer over. Now it will work no freezing :)
May 31, 2009 | Gateway MX8711 Notebook
YES ITS TRUE!!!! My copy of Fable 2 only started freezing when I accidently shut off the console while it was saving. I haven't even downloaded the expansion. Now everytime I go to load my save it freezes...
Because you shut down the console halfway during saving, your save game might be corrupted. Now, I don't remember much about Fable 2 but I think that it - unfortunately for you - only uses one save game which is probably corrupted now...
Mar 17, 2009 | Microsoft Fable 2 for Xbox 360
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
Freezing computer after loading security cd.
Start your computer in SAFE MODE and remove the norton.
To do that >> Turn off your computer >> turn on ...and before windows loading hit F8 and select SAFE MODE
Nov 05, 2008 | Acer TravelMate 2300 Notebook
Computer will not load.
use safe mode..do a disc clean, defrag..and then reboot...sounds like the operating system headers went unhappy when you moved it(which I highly recommend you NOT do again)..
May 25, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
"refresh database"
Get the Vista compatible version of the software from Sansa's website
May 24, 2008 | SanDisk Sansa e260 MP3 Player
Microsoft HP Pavilion DV6276US Notebook PC Logo
1,184 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
