Question about RCA HD50LPW175 50" HDTV
RCA Scenium DLP wont turn on, light comes on after I plug it in
As soon as I plug in my RCA DLP Scenium HD50LPW164, the power light comes on and won't turn off.
Acording to the user manual...
"When you first plug your TV into an outlet, the Power indicator on thefront panel will light and blink for approximately 30 seconds and then go off during the initialization of the TV. The TV can only beturned on after the Power indicator goes off. This happens every time power is reapplied to the TV."
It seems that the system never finishes its power initializationsequence. The only noise I hear is the fan spinning. I'm thinking maybea fuse or bad power supply? or perhaps a bad ballast? Is theresomething I can do to test these components before I blindly buyreplacement parts?
  • 6 more comments
  • Anonymous Nov 26, 2008
    I have the identical problem
  • jamesharhi Dec 03, 2008
    Power on and power light stays on. It does flash like the bulb is bad. unplug for 10 mins and problem is still there. no picture, no sound, unable to change inputs.
  • tomandjerry Dec 14, 2008
    I have same problem. led lights stay on, but no sound or picture.
    same problem led lights stay on, but no picture or sound.
  • tdoby1 Dec 17, 2008
    I have the same problem. It was happening about 6 months ago and I thought it was the lamp. I haven't used it, but just bought and installed a new lamp and same problem. Worked for 20 minutes. Turned off the TV and back on and nothing. When I unplug and replug I hear a power sound and the power light goes on. Anyone had this fixed and know the cost? Is it worth it? I can't return the lamp now since it's been used (for 20 minutes). I did get the lamp for an excellent price on Ebay and it worked great for the 20 mins.
  • Anonymous Dec 26, 2008
    I have an RCA Scenium 61" DLP and when i turn it on the lights flash and the screen never appears????
  • drlfries Jan 09, 2009
    I have a 61"DLP rca projection... replaced the color wheel cause initially it was just a loud screeching noise... then got sound but no picture.. bought a new lamp bulb... now turn on and same thing.. seems like the initialization period never stops... light goes on fan turns light blinks like 5x and then fan stops and light goes solid again...heard maybe ballast, or power supply and or capacitors? would love a way to test it without just dumping anymore money into this thing! thanks for any help in advance!
  • marios313 Apr 23, 2009
    I have the exact same problem if anybody has a solution please post it I have 2 different threads on 2 different forums... please post any knowledge you have on this issue...http://www.highdefforum.com/rear-project... andhttp://www.avforums.com/forums/rear-proj...
Slinteriors
  • 8617 Answers
SOURCE: RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: I have an RCA DLP M50WH72S tv. Powers up, picture
the most likliest issue is the color wheel needs replacement
Posted on Jul 17, 2009
yambo
  • 230 Answers
SOURCE: 61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Posted on Jul 26, 2009
techman
  • 3130 Answers
SOURCE: how can i check my lamp ballast in a rca scenium
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
(AKA) (TECHMAN)
Posted on Sep 04, 2009
I have a Rca scenium tv ...trying to connect to my hd reciver and can not get a picture ...tried hdmi cord ..adapter ..dvi cord ..and nothing at all
Easy to understand, hooking up RCA, HDMI, and othe ...
? 5:54
https://www.youtube.com/watch?v=m4jgK7Ws_6U
Jul 10, 2012 - Uploaded by kevintalkstech
A very easy to understand tutorial about what RCA, HDMI, coaxial and ... +kevintalkstech I am trying to learn ...
How To Connect: Tv + Component With Dvi Or Hdmi - Rca ...
www.manualslib.com > ... > User manual
RCA SCENIUM HDTV With DLP Technology High-Definition Television ... To connectyour TV to a component with a DVI jack, use an HDMI cable and an ... Note: You canset up the TV to automatically tune to the correct Video Input Channel. .... call me at 318-578-5198 I need help as soon as possible trying to get my tv to ...
Support - RCA Television
Dec 27, 2015 | RCA Televison & Video
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Color wheel
The motor is nothing more than a harddrive motor, not sure that was the right solution but.... I would suggest that your chassis is not in the right location. Verify that the chasis is centered on the mounting bosses. The screws might be a good clue. Good luck.
Jul 05, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium DLP
Usually that is an indication of a bad lamp. A lamp can be ordered and replaced yourself. Use the model number of the television to order the correct lamp.
Jan 30, 2009 | Televison & Video
RCA HD50LPW164
It is very well possible for new lamp to be bad ?
Dec 09, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA HD50LPW175 50" HDTV Logo
1,515 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
