Question about Sharp AR-M207E Black and White Copier
The toner cartridge replacement won't fit
Our office just bought a Sharp AR-M207 copier, the toner ran out, we ordered a new toner cartridge and it won't fit. It looks similar but when you slide it in it won't go in all the way. We called the service center, and they insist the replacement is supposed to fit. A service guy came in and he confirmed there is something a little different.
I was just wondering if you ever heard of this problem before on these models.
  • Sharp Expert
  • 1,326 Answers
Yes it is possible that they did not send you the O.E.M. toner cartridge. Some of the gerneric toners are made for a few different models and they may not fit exactly.
Posted on Nov 21, 2008
Hi i refil the toner for my sharp ar-m207 and later the copier say add toner can not print or copy help my please
You have to replace the whole toner cartridge because there is a crum chip on the back of the toner cartridge. When the cartridge reaches empty and the copier says change toner the copier burns that chip so it can not be reused again.
Aug 24, 2011 | Sharp AR-M207 All-In-One Laser Printer
ARM207 SHARP F2-O4 PROBLEM
That means it is the wrong toner cartridge. You should be using a toner cartridge AR-202NT.
Jul 27, 2011 | Sharp AR-M207 All-In-One Laser Printer
F2-04 ARM 207
That means you have the wrong toner cartridge in you copier. You should be using an AR-202NT.
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Changing a drum cartridge
Open the right side door, open the front door, remove the toner cartridge and look inside. There should be a blue screw above the hole where the cartridge goes, loosen it and then remove the developer unit. At this point you can grab the black cover just to the right where the toner cartridge fits and pull out the drum unit.
Jul 30, 2009 | Sharp AR-M207E Black and White Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-M207E Black and White Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
