Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
RCA 3 Device U. Rmte & Motorola Cable Box DCT-700. No Sound!
Everything works fine except volume. The super remote that came with the cable box works volume up and down. The RCA does nothing when volume up or down is pressed except light up. The RCA remote controls volume on the old Zenith TV with no hitches. Having to switch between TV and Cable buttons to control volume is no problem for most of us, but this set up is for a technically retarded elderly person forced into this by the upcoming digital conversion. Is there any solution(s) out there? If not, can anyone suggest a very simple universal remote that will work all functions on a Motorola DCT-700?
Thanks.
SOURCE:
  • 112 Answers
SOURCE: rca code guide
This is a link to the codes to program your remote control to any television. You may have to try every code listed under the zenith model before you find one that works
http://support.rcaaccessories.com/doc/aud1736.xml?docid=761&docid=983&navtypeid=6&pagetypeid=7&prevPageIndex=1&selectedmodel=RCU600M&selectedFamily=audio&lid=y
Posted on Jan 22, 2008
dauphine
  • 207 Answers
SOURCE: universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Posted on Apr 10, 2008
centralhigh
  • 260 Answers
SOURCE: RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Posted on Jun 25, 2008
SOURCE: anyone have the code for a broksonic tv using an rca universal remote control?
215 and 316 might work.
Posted on Aug 12, 2008
there is no "code search" button on the RCR3273???? can anybody help?
Posted on Aug 31, 2008
I need codes for my cable box its a moterola cable box from shaw in winnipeg manitoba my name is justin ledoux could you send me some codes pleaz
Sorry it took so long to respond to your request for assistance.[Motorola... 5000, 5002, 5003, 5028] These are the listed codes for your remote control to use with a Motorola cable box. I hope this information solves your problem, of needing the codes to use with the remote control and you Motorola cable box. Thank you for using FixYa and have a nice day!
Feb 10, 2009 | RCA 3-Device Universal Remote with...
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
I have no sound!
Are you using a cable box or is your input through the coax cable or antenna? If you are using a cable box with RCA connections make sure the Red and Black cables are securely plugged in both the cable box and the TV. Check to see if your TV has sound by going to the antenna input and select any channel and crank up the volume. If you don't hear anything you'll probably need a new TV.
Jul 08, 2008 | RCA F27615 27" TV
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
172 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
