Kenmore 43142 Front Load Washer
Problem for Kenmore 43142 Front Load Washer
Repair front load washer
By prontis on Dec 15, 2006
not spin at theend of cycle washer frontload
Same Problem
Apr 21, 2009
-   I paid my front loader off at Aaron's rent to own and when i paid it off the way the guy explained it to me i had a six month warranty after pay off. my washer quit spinning two days ago and i called them and they said they would come out. last night the wahser quit all together. none of the lights on the display are working expect the door lock emblem. when it's plugged in it sounds like it is continously running but its not doing anything!!!! i have standing water in my washer that won't drain. i have only had my washer for less than 3 months and now they won't come fix it supposably i only had 60 day warranty. i need the most inexpensive i may be able to fix this. any idea!!! HELP!!!!-   kherman454
Oct 20, 2008
-   front load washer haier hwm126ok will not finish the wash and spin the clothes dry. tells me it is error 3.?-   swado2
Sep 23, 2008
-   washer will not spin in any cycle. the promlem is intermitting. something is ether loose or getting ready to go. what part could cause this problem? the repairman does not know.-   darrach
Aug 27, 2008
-   washer hums but will not spin-   Guest
Aug 14, 2008
-   My front loader has stopped spinning. I will try the posted repair and see if that works for me. -   beautycat
Best Solution
posted on Dec 24, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sounds like the same issue I'm having, I will look at the area you suggest.
thanks,
Rog
Solution #2
posted on Jul 04, 2007
Helpful)
Buzzard
Rank: Apprentice
Rating: 91%, 17 votes
We've had that same problem since we bought ours 3 years ago...but it was intermittent, and we never knew when we'd get the spin-dry cycle to work. Sears made 10 service calls, and replaced everything in the machine except the motor and motor control board. Those two parts were ordered and delivered as a result of the 10th service call. Of course, when the service guy was here, the spin worked! After he left, the next load did not spin. Frustrated, I opened the front end and looked around. I had noticed how violently the drum shook while operating when the service guy was here, so I decided to see if the wiring harness from the motor might be loose where it plugs into another harness that must go to the motor control board. There was a definite tightening of that connection as I squeezed the two harness plugs together. (I tightly secured a plastic zip-tie around that connection to prevent it from vibrating loose again) Since then, I have had absolutely no problem with the washer. I called Sears and told them I had managed to solve this long-standing problem on my own, and how, and also told them to cancel the service call to install those parts I ordered, but to pick them up and reimburse me for them. (I never opened the two boxes that arrived) They did just that, and we finally have a washing machine we can rely upon to complete the wash like it's supposed to. It's been a very frustrating and expensive 3 years, but now all is well.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore 43142 Front Load
Questions and Unsolved Problems for Kenmore 43142 Front Load
Do you recommend Kenmore 43142 Front Load Washer?
Answer
Answer
will not always dispense fabric softner and bleach
Answer
Kenmore front loading washing machine won't open. I ran a load and it did the final spin and the... (More)
Answer
when you press start the front door locks,does not fill with water and will not unlock had to take... (More)
Answer
my front load kenmore washer stops after the wash cycle. Then if manuallly placed on rinse it will... (More)
7 Other Users Have The Same Problem - Continued
Comment by MIKE36, posted on Apr 06, 2008
my washer stops between each cycle. I have to manually turn the handle between every cycle. clus anyone?
Comment by Guest, posted on Apr 04, 2008
kenmore front load washer - does not spin dry - clothes remain very wet
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
