Question about Crosley CR248 Turntable
Turntable arm stuck in play position
The turntable arm will not return to the rest position. It's stuck in 45 position. Can't find anyway to reset it.
  • Anonymous Jan 02, 2009
    I just bought a used turntable, and I have the same problem. When the record is finished playing, the arm lifts off and goes back only to the 45 position and then drops down onto the record again - when it should go all the way back over the cradle and drop down on the cradle, thus stopping the turntable from moving.
    I cannot seem to find a solution anywhere online.
    Thank you for any feedback you can offer.
  • outilleur Jan 02, 2009
    I have the same problem. The play finishes, the needle comes off the vinyl and returns to only the 45 position and then drops down onto the vinyl again and plays starting at that point, and on and on it goes. It should of course lift off the vinyl, return to over the cradle, drop down on the cradle, and then by virtue of this, the turntable mechanism should stop. Cannot find any solutions anywhere online.
5 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Crosley CR79 4 in 1 Entertainment Center
Wild guess but try this with the power off. Rotate the platter clockwise about 5-10 turns. You may feel internal mechanical engagement as you do it. The cueing mechanism may cycle it through its motion and return it to the rest.
Posted on Apr 04, 2009
  • 222 Answers
SOURCE: Haven't used the turntable in years. Went to use
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Posted on Aug 21, 2010
tbreeze47
  • 3083 Answers
SOURCE: The turntable on my CR245
Haven't worked on one of these, but there is an end of travel arm sensor that needs adjustment, or is possible broken. You will have to get inside to check it out, and adjust or fix it.
If you don't feel comfortable fixing it yourself, contact Crosley support:
http://www.crosleyradio.com/supportForm.aspx
Good luck, and hope this helps.
Posted on Feb 03, 2011
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Arm stuck in middle of turntable won't move forward or return to rest
if the arm is automated and someone forced it to move, it could be that a gear is jammed. Open the unit to access the mechanical mechanisms and look for any stuck gears or pieces, turn on the unit and see that the motor is attempting to respond.
Dec 15, 2013 | Crosley 4-in-1 Entertainer CD Shelf System
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Nov 09, 2011 | Crosley 0187SST Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
My prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Jan 06, 2009 | Audio Players & Recorders
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Crosley CR248 Turntable Logo
60 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
