Question about Kenmore Energy Star 44092 Front Load Washer
Kenmore front load 4409250, How do I open the head?
I suspect my cold water valve is stuck in the closed position. I can get hot water, but only a buzzing/grinding sound when trying to use cold water. I cannot figure out how to open the head of the unit to test the water valve switches. Can you tell me how to open the top of the machine?
Thank you.
    Genius:
  • 1,028 Answers
Remove 3 screws along back edge of cabinet and slid top back but first be sure there is water to washer also remove hose at inlet end and ck screen for sand or other debris
Posted on Nov 20, 2008
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
The machine is off and the water keeps running
When this happens, that means the water inlet valve is not shutting off. EIther the valve is stuck or there is still power going to the valve keepng it open allowing water flow.
Nov 10, 2010 | Kenmore HE2 Plus Front Load Washer
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Constant water flow with machine on or off
It seems reasonable to me that the machine has a solenoid spring loaded to the off position and electrically opened to allow water in. Check the temperature of the water coming in. If it is cold then the fault is in the cold water valve, if hot then the hot water valve is the problem. I suspect you need a new water valve.
Feb 26, 2010 | Maytag Clothes Dryer Almond Timer Knob...
My Kenmore 110 92587210 Washer is slowly letting water in
The solenoid for the cold water valve has failed in the open position and needs to be replaced. The valve unit is for both hot and cold. It is the item that the water hoses are connected to.
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water not working
You say the cold water hose works on the hot water side? Or did you mean you've already eliminated the possible problem of new hoses?
If that is the case, it's definately water inlet valve. Sounds like you have a blockage in the screen (check that for me). If there's no lint stuck in the hot water screen, then you need to replace the inlet valve. It's possible the solenoid of the inlet valve on the hot side is stuck shut only allowing the cold to fill. Before you buy a new valve, take the old one out and play around with it. The plunger like solenoids will come off and you can check for debirs in there. If there's debris, clean it out and try the cycle again. If there's not debris, the part needs to be replaced.
Here's the part:
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=299098
Feb 24, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water thru out the house
The problem is solved, it was a single handle shower valve in the open hot position when my wife washed her hair, she turned the water off at the shower head. This forced hot water into the cold pipes when a faucet down the line was opened. Thnks for the help.
Aug 08, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
