Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Buzzing sound, freezer nor fridge cooling
This fridge is barely 5 yrs old! It buzzes for a few seconds, shuts off, buzzes again, and items in the freezer are melting.
It's model No. FRT18H6CW.
Obviously I'll need a repairman at god knows what cost -- and I'm REALLY aggravated to have this problem already. Know of any other people with the same prob?
  • 2 more comments
  • tdragert Nov 20, 2008
    Great ! But I didn't purchase any additional warranty time -- think the 5 yr approach is still applicable?
    Tobi
  • tdragert Nov 22, 2008
    no help. But the service provider in the L.A. area gave me the number for customer service of Frigidaire and they were super helpful.
  • janrx Dec 15, 2008
    We got the model No. FRT18H6CW last summer. it is just over a year. worked well until a few days ago, it buzzes for a few seconds, shuts off, buzzes again, and items in the freezer are melting. What should we do?
  • Bill Newberry
    Bill Newberry May 11, 2010
    Here are some factory service manuals.  These are handy to have around.
    Thanks,
    Bill
    http://www.applianceoutletservice.com/fr...
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like a compressor issue, perhaps the good news would be if its just under 5 yrs, youll have a 5 yr warr onthe compressor assy.( you should anyway) ck your manual for warr info
Posted on Nov 20, 2008
  • Ron Coons
    Ron Coons Nov 20, 2008
    your extended warr, that you purchased is in addition to , not excluding any existing manufacture warr. call your extended contract provider first though( they are usually also authorized manufacture repair personnel as well.
Maytag fridge stops cooling, then 1-2 days later restarts on own
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
Let us know what you find!
Feb 21, 2018 | Maytag MFD2561HE Bottom Freezer French...
UNIT (ABOUT 4 YRS OLD) STOPPED COOLING FREEZER AND FRIDGE AND MAKES A BUZZING NOISE ABOUT EVERY 5 MINUTES.
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Dave
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Ice is melting and unit is buzzing for a couple of minutes then stops, then starts buzzing again. The refrigerator is approx. 5 yrs. old.
It sounds to me, unfortunately, the compressor is locked up. You could either have a tech change it out or replace the fridge.
Jun 20, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
197 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
