Water Leakage / Samsung SW61ASP
How do I fix water leakage from the back panel of Samsung Washing Machine (SW61ASP)?
james klgr
  • 362 Answers
SOURCE: leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Posted on Dec 22, 2007
Yozzer6821
  • 116 Answers
SOURCE: front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Posted on Apr 08, 2008
  • 1531 Answers
SOURCE: How to replace the door diaphragm on a Samsung
remove the lid.then you need to take off the control panel move it out of the way.there will be a spring that holds the boot in place on the front where the door closes remove this spring the rmove the boot from the front panel then remove the front panel.there will be another spring that holds the boot to the drum.i have found it easy to remove the counter balance weights to remove and reinstall the new boot. i hope this helps sounds like alot but not real bad
Posted on Sep 19, 2009
  • 141 Answers
SOURCE: water leakage from under washer, and black grunge
The problem is washer unit bearing are damaged kindly replace the inner bearings and the washer to support the the bearings
Posted on Jan 03, 2010
  • 714 Answers
SOURCE: water leaks when draining
sounds like the drain pump is leaking
Posted on Feb 21, 2010
E1 message on smeg DWI 614
see this causes and fix it. God bless you
E1--Leakage error--Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection (sink drain hose) is not over 20". Impeller of the washing pump is worn away
Sep 28, 2012 | Dishwashers
Water leaking on spin cycle on whirlpool washing machine
Check 4 the connections of water pipes... for leakage..!!!! if leakage is found in specific spot.... contact The nearby whirlpool service station..!!!! Also contact customer care online at "http://www.whirlpoolindia.com/" or "http://www.whirlpoolindia.com/CustomerCare.aspx"
Mar 22, 2012 | Whirlpool LSR8233J
Water leakage from washing machine
if water leaking only when draining it seems you have a leak somewere on the pump or conecting pipework the only way you can tell is by checking it wilst it is draining then you will know what needs replacing
Dec 21, 2011 | Washing Machines
My front loader washing machine shows F 9 on the digital screen which relates to water leakage. I have had this problem recitified previously, wherein water somehow leaked into the bottom of the machine,...
Sorry but Whirlpool 'F09' does state 'overflow'. It could be that the overflow sensor is being a bit keen i.e. malfunctioning, and needs a service call ;-0(
Sorry again,
John C
Apr 08, 2011 | Whirlpool Washing Machines
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
Error code E1
E1...LEAKAGE ERROR-displayed-
The excessive RPM of
Washing Motor
happened during Wash
cycle due to water
leakage.
Water leakage in Hose connections.
Water is leaked by damages.
The Motor Water Seal leakage of
Sump assembly.
The height of Drain Hose connection
(sink-Drain Hose) is not over 20 .
Impeller of the Washing Pump is
worn away.
Replace the connections of Hose.
Check the point of damages and
repair or replace the related parts.
Read the Installation Instructions
(page 9) and fix it to the
recommended Height.
Replace the Impeller of the
Washing pump
this is from your manual any more questions please message me back thanks again
rickead1
Sep 02, 2010 | LG WM2487H Front Load Washer
E1 comes up on screen and alarm goes off, how do I fix it?
Leakage error > Condition: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Solution:
Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
Mar 25, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
I keep getting an E1 error on my LG LD-2120W model dishwasher, can you advise what this means so l can either fix it or get it fixed. Thank you
leakage Error E1
  • The excessive RPM of Washing Motor happened during Washcycle due to water leakage.
  • Water leakage in Hose connections.
  • Water is leaked by damages.
  • The Motor Water Seal leakage of Sump assembly.
  • The height of Drain Hose connection
  • (sink-Drain Hose) is not over 20 .
  • Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
fix it to the recommended Height. Replace the Impeller of the Washing Pump.
Sep 27, 2009 | LG Dishwashers
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Aug 30, 2009 | LG Dishwashers
Samsung
hey this soundslike your washer might be syp[hening out your water which means that the drain hose is lower than the washer.another soluthion might be leakage,how high ias the hose or is there any water on the floor? good luck
Oct 19, 2007 | GE WBSE2090A Top Load Washer
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
