How can I get rid of the mildew-like smell in my Bissell Little Green Machine? What's the best way to remove hair/clumps of dirt/carpet that are stuck in hard to reach parts of the machine?
SOURCE: How do you operate the Bissell 1725 LittleGreen Machine Proheat
Go to www.bissell.com then click the Customer Service tab. In the next window click on the User Guides link (in green on left hand side), then enter your model number. You can then download the full instructions.
SOURCE: Cleaning the bissell little green
We took off the hose by pushing in the 2 white pins on either side of the hose at the end near the base.BE CAREFUL NOT TO PULL ON THE HOSE ITSELF but on the plastic where the hose connects.Flush water thru the hose to clear out all the mildew and junk thats caught up in the hose. Reconnect the hose by pushing back on and locking the pins back in. It'll start smelling better immediately.
SOURCE: need user guide for older Bissell Little green
Call the 1-800 number on your product. It should be on the bottom or behind it. Hope this helps!?
Please rate solution - Thanks.
SOURCE: bissell little green machine will not spray
The Pumps on these go bad after a couple of months. They rust and will
sometimes spray and other times not then eventually not work at all. If
your a handy man pull the top off it and remove the pump motor and
replace it yourself. The part number is 603-5029 you can put this number
in google shipping and get it to your door for about $15 and replace it
yourself or have a friend do it. Ebay has tons of them once again just
put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
SOURCE: I need the instructions for the Bissell Little
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
