Question about Vivitar ViviCam 8400 Digital Camera
With new batterys i only get about 15 photos
I bought new batterys when i charge them I only get 15 picks
Buy Lithium AA Batteries, instead...you will be amazed at the difference. You'll go from 15 pictures to about 200 pictures. Hope this helps!
Posted on Nov 29, 2008
WHY DOES MY CAMERA take 10 photos & my new recahrgeable batteries die!
Not really. The only "extra" energy required is the use of the flash and 10 photos should not affect that. You said it was a "new" battery? You might take it back to where you bought it. Are you giving it enough time on the charger to fully charge? If the battery is new, your first charge should at least night.
Good Luck
Aug 03, 2014 | Kodak Easyshare Z812-IS Digital Zoom...
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Brand new battery won't hold charge. Camera is three years old. I bought an extra battery when I bought the camera. They both seemed to go bad at the same time, so I recently bought two new lithium...
if this happens even to new batteries, it may no longer be an issue with the batteries, but it can be an issue with the camera itself. check the maximum number of shots that the camera can take with the batteries per its specification. if it should produce more, it would be a good ide ato check with Canon to have the camera checked.
Sep 06, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Camera only takes 5 photos before dying
This new battery, if it is the exact type of battery recommended by the manufacturer then it is most likely not the battery. if you bought a similar battery it might be for even the minimum difference makes all the difference with digital cameras. for camera repair this company does a good job and you can even select your problem on their online quote. www.teleplancamerarepair.com
Jul 08, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Optio E10 Keeps running thru batteries, I bought a new 8 pk for a field trip with my sons school, I took 5 pictures and had to change batteries, placed in anew set and it wouldn't turn on. waited about 15...
This sounds very much to me like a short circuit causing the batteries to drain so quickly. The most common cause would be moisture or water damage. Another likely cause could be a malfunction of the control circuits causing the unusual power drain. ie the camera may be continuously charging the flash.
It may be time to consider this camera has seen better days and find a replacement, unless of course it is still under a warranty.
Oct 19, 2009 | Pentax Optio E10 Digital Camera
2004 polaris predator 500 3 new batterys dying can't charge them
I hope you got this problem fixed, just happened to my predator, it was indeed the voltage regulator. I picked up a service manual that includes part numbers and installation procedures from www.promanuals.net for 15 bucks.
Mar 21, 2009 | Polaris ATV
Battery
is the battery charged. normally the battery need to be charged for 24 hours.
just put the battery in the laptop and charge it. if it still do not recongnise it after that. then you nee to go into BIOS had set the detection on.
Sep 30, 2008 | Computers & Internet
Vivitar ViviCam 8400 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
