Question about T-Mobile Sidekick II
Sidekick Lx screen is white with 4 black symbols on it
Whenever i plug the phone in to charge the screen automatically turns on, its white with four black symbols(the same four symbols that are on the buttons on the front of the phone). even when it's not plugged in, the screen stays that way. it's not letting me turn it on, or shut it off. what do i do?
Well dude i can help you i JUST fixed my friends cell we were searchin online fo a solution..
do this step as follows
1. remove the backpiece
2. remove the battery
3.remove the sd memory card
4.place the battery back in the supportive slot
5.re attach the backpiece
6. power up the fone
and wallahhhhh!!!! ^_^
the memory card is the problem
he placed the card back in the fone and the problem continued ...
u may need to purchase a new sd card
Posted on Dec 05, 2008
No pixels on my sidekick LX!
k u need a new lghit for screen
Feb 25, 2010 | Sharp Sidekick LX Smartphone
Low free storage alert on my tmobile dash
you have to do a master reboot on the phone.. that will clear up the things that you cant erase... Hard reset:
1. Power off
2. Push both white dash keys and power up.
3. At T mobile screen it will change to black with writing and instructions.
4. Let go of soft keys and push send (follow directions on screen).
5. Formatted!
Jun 06, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
My sidekick will not come on
You can try the procedure at the following link:
http://www.fixmysidekick.com/sidekick-3-shows-4-symbols-on-white-back-ground/71/
It should work for you.
I hope that helps
Dec 18, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sony ericsson c905 screen not working
GO TO THE SONY ERICCSON WEBSITE, PRESS SUPPORT AT TOP OF PAGE, SELECT PHONE ON LEFT (C905) then above the picture press software downloads, then press Update your product software, then press read and download, follow the instructions once loaded, remember to have the usb /sony cable ready as you will need to plug phone into computer, phone needs to be fully charged and needs to be turned off, good luck !
Nov 10, 2008 | Jabra T-Mobile Wing / Dash / SDA /...
Sidekick LX won't charge
This is a COMMON problem with the Sidekick. Not just the LX but the whole line. You'd think they'd have solved it by now. Anyway, I have a WORKAROUND to bypass your problem. It won't fix ibad charger port, but it will charge your battery for only $5. Go to ebay. Type in "universal cell phone charger". Dozens of these should come up. Most are some variant of a generic China made round charger. They have clip on electrode probes which touch the contacts of your batteries and holds them to recharge them. They work not only with most cell phone batteries, but with digital cameras and pdas too. Anyway, order one that has a good instruction sheet or description. I wasted a whole day recharging one of my batteries the wrong way because the instructions didn't come with it. Generally, the more buttons, the better. These chargers are cheap and dinky looking, but THEY WORK! I charged up a Sidekick 3 battery with one. The only real issue is that they take some time to charge up . At least my SK3 battery did, simply because it's so big. I'd get another battery on ebay and TWO chargers for a total of under $12. Some of these chargers are as cheap as $3 each. I'd have one bat charging and another ready to go just to get around the longer recharge times. For $12, beats the hell out of the $35 I'd have to pay for a Sidekick 3 battery charging cradle!
Sep 11, 2008 | T-Mobile Sidekick
Sidekcik Lx will not charge.
Try a new battery for it.
Sep 09, 2008 | T-Mobile Sidekick
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick lx
When you take out your battery wih out shutting down it erases everything but only for about an hour everything does come back it does not erase it forever! Just to let everyone know! Of course if you have an option besides taking out the battery then use that but waiting for it to die is just silly and would take forever!
Jun 19, 2008 | Sharp Sidekick LX Smartphone
T-Mobile Sidekick II Logo
305 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
