Question about Acer Aspire 5500 5570-2609 Laptop
Power hello,I have an acer aspire 5570, when I will to use it, it's can't trun on, I have to try test the charger and the battery but it same not respons, please help me to solve my problem
    Scholar:
  • 65 Answers
Did the battery seem to lose it's charge rapidly prior to this, this would be an indication of a battery losing it's useful life, or a problem with the charge system.
Have you tried to take the battery out, plug the computer to a wall outlet granted you have the power adapter which is the same as the charger cord I would think. If that works I would say you need a new battery. Sometimes the plug port where it connects in the computer wears, so try and wiggle the cord if you didn't get something the first time.
Matt
Posted on Nov 25, 2008
Acer aspire 5516 battery and charger problem
Hi, this could be an unhelpfull suggestion but the charger may not be compatable with your laptop. Laptops notoriosly have different power settings, you may be forced to purchase a new Acer charger. Try ebay, you may be lucky
Aug 01, 2010 | Acer Computers & Internet
Mouse pad been working fine, but now not working on acer aspire 5732Z i had for christmas. can i fix or will i have to return to shop?
hello, i have a suggestion for this kind of problem. Try to do a power drain. First you have to power off the computer, remove the battery and ac adapter and anything that is plugged on to your computer. Press and hold the power button for 15 seconds. Put the battery back and the ac adapter, try to power it on and test it. If still doesnt work try to uninstall and re install the driver for your mousepad. Hope this helps! goodluck!!!
Jun 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hi, I own notebook Aspire 5570. I have problem to turn my NB on. When I push 0/I button, nothing happened. My friend checked adapter and battery, both are OK.
Please try the steps below..
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Conncet the charger (don't connect the battery yet) and try to start by pressing the power button.
Also listen carefully for any beep sounds if you hear beep sound then the rams could be defective otherwise the mother board seems to be defective.
Feb 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
My acaer aspire laptop keeps switching itself off
If the computer turns off instantly after the power is pressed, either you are not plugged into the charger and the battery is empty, or there is a hardware fault that is preventing it from starting up properly.
if you are plugged into the charger and the battery has power as well, then try unplugging the power and take out the battery for 5 minutes, plug both back in and try to turn it on. if the same problem repeats then it is most likely a hardware issue.
If you are in warranty contact acer or your dealer, you will have to send / ship the laptop to acer warranty repair, more details from acer or your dealer.
If you are outside of warranty, take the laptop to a local professional for a diagnosis and a repair estimate.
Nov 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
Oct 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5570 does not power on with the charger plugged. It also does not come on with the battery. Charger has a green light
Sounds like your power processor is on the fritz.
It may costs between 150 250 dollars to have a new one installed. The processor itself can be had for as low as 75 dollars if you look on the internet.
If it is under warranty, send it back.
Oct 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
No power
check first the charger, if its working check the dc jact connector need to open you unit.. then check if the battery is not working when you remove it should be work even withtout the battery..
Sep 11, 2009 | Acer Aspire 5500 5570-4421 Laptop
Acer Aspire 5570z
don't worry about it! A lot of chargers blink. Mine does, it just means its charging, and no not having a battery won't affect it
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
