Question about Toshiba Satellite M30X-S191TD (PSA72U3HJ01L) PC Notebook
Toshiba Satellite M30X-S191TD killed by lightning
Surge on the phone line to the modem took it out. Now no lights, no action, no nothing. I suspect the motherboard is fried, but could it be the power supply or a short in the modem? Maybe even a fuse?? If it's the mobo, must I replace it with the exact same one, or would one from another related Toshiba model (M30, M35, M?? line) also work? A quick scan of the web turns up a few replacement mobos in the $300-$400 which seems like an awful lot to spend to resurrect a 1.4GHz celeron-driven laptop. Anybody know which component might have popped when the lightning hit? I used to do component-level repairs on pcboards, so no prob replacing a cap, diode, or whatever.
Thanks!
Martin
I need ethernet contoroller drivers, where can I fund its?
http://download.cnet.com/toshiba-modem-ethernet-pc/3000-2112_4-82021.html
http://download.cnet.com/toshiba-fast-ethernet-pci/3000-2112_4-90651.html
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise) exclude - / you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers
hope this helps
Jul 11, 2012 | Toshiba Satellite M30X-S214 M30X-S1593ST...
Need manual for toshiba m30x laptop
Scroll down and click "Download the Manual"
http://www.retrevo.com/support/Toshiba-M30X-S181ST-Laptops-manual/id/614ci469/t/2/
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Toshiba Satellite M30X-S181ST Laptop
My sister in Charlotte, NC had a couple of seconds power outage, her processor, modem, monitor, tv and phone were connected to outlet thru a surge protector. All work except processor. Is there a reset for...
No reset for that processsor.. ALL Surge protectors are not guaranted for lightning strikes. Does she know if lightning hit the line that services her home?
Jul 13, 2010 | HP Pavilion a1540n PC Desktop
No power on TV - JVC LT-47X788 47 in. HDTV LCD
Power supply board is dead.U have a LED light indicator on LCD panel flashing?The tv is completely dead,no LED light at all?Tries Website like Shopjimmy.com.Ebay.com to buy a refurbish power supply for the replacement.
May 07, 2010 | JVC LT-47X788 47 in. LCD HDTV
My 2003 server sees the modem v.92 fax, but i can not seem to use it. I tryed to reset it, powered off and back on, reinitialized it but nothing seems to work.
A lightning strike to the phone line can kill the line interface while the computer interface is still ok. This would produce the symptoms you describe. If you can open the modem, look around the phone line connector for burnt components or burning on the board.
This might also stop the phone line from working when the modem is connected, ie another phone on the same line will produce no dial tone with themodem connected.
If this is the case a new modem will be the cheapest way out of this.
Apr 20, 2010 | USR5686E, US ROBOTICS 56K V.92 EXTERNAL...
I Have Toshiba satellite M30X PC Notebookm. I have a problem with my usb cann't detect any port flash card, mouse, webcam, I have window xp sp 2 please Help,
HI there i am sure your laptop is virus infected. I was faced the same problem. After that i format the OS & again install that. So i suggest you the same thing. Thanks.
Apr 03, 2010 | Toshiba Satellite M30X Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Toshiba Satellite M30X/m35x
Try an external monitor - if that works then your screen or cable is faulty. If not try replacing the ram - if you are using two sticks of ram try booting with each stick individually to see if one of them is faulty. If it does not show a display with known good ram of the correct type then it may be the processor that is faulty.
Mar 16, 2008 | Toshiba Satellite M30X Notebook
HUMM in phone line(modem)
turn off the mic or the extrernal speaker if this dosent work there might be a problem with the phone cord or your house wires
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 25, 2007 | HP Pavilion dv1000 Notebook
Toshiba Satellite M30X-S191TD (PSA72U3HJ01L) PC Notebook Logo
209 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
