Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
Lightscribe enabled drive opens
Lightscribe enabled door opens and closes intermittently.. Sometimes the screen reads "eject" sometimes not..
Happens whether there is a disk in it or not..
Seems to happen whether the computer is being used or not..
What's up..
  • HP Master
  • 2,404 Answers
Sounds like there might be debris that is keeping the door from closing all the way properly so when that happens it can make the door open up from time to time.
IF you don't have debris, could also be that the mainboard inside of the drive is going bad and causing the door to open and close on its own.
Change out the drive with a new one cause not only will that take care of the door problem but you'll have a new laser in the new drive and will last much longer.
Posted on Jun 29, 2009
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
Why does a chime ding intermittently, always twice?
Door open chime? Mayhem defective door switch
May 13, 2017 | 2007 GMC Envoy Denali
I can not close my my Chamberlain garage door. It tries to close, and reach the end, then somehow after a second pause it opens. sometimes, wait for 5 minutes, it closes normally. This happens only when...
It sounds like the door is closing just a little too far. It hits the garage floor and the safety reverses it to the open position. This can be intermittent. On the side of the motor unit you will find the 'down limit' adjustment. Turn this just a tad in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Jul 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door always opens, intermittant stopping when the door is closing. Sometimes it closes all the way, other times it stops repeatedly and you must press the close button many times to get the door to close....
Sorry to say,u should of replaced the whole control box.This is not a sensors problems,it the control box problems.U know basic electronic's and soldering?Take the control box aparts,check for these bad capacitors leakages,these capacitors alway have the top of it bulges or puff up.These capacitors not giving it max power that why it work sometimes,sometimes don't.Replaced these leakage capacitors,ur power should return yo normal.
May 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
After 2 years it now gives a no disc or unknown disc message.
Hi, there!
This are some reasons for this :
the reading lens as become week so needs replacement .
2, disk compartment mechanism is not perfect sometime the lens is not brought to right possition to read disk , reasons worn out belts especially loading tray belt. change this belts .
Good luck
Dec 28, 2009 | TruTech TT1620 DVD Recorder
The tray wiyll not stay closed and sometimes will not open or closed.
maybe you have bad contact in micro timing switch, and this micro switch needs cleaning then test run.
Jun 06, 2009 | iLO DVDRH04 DVD Recorder
HP dvd 940 i lightscribe---tray sticks
underneath the tray there should be this little hole. if you see that hole insert a pin in it, and the press the eject button and push in the pin at the same time. that should make it work
Apr 04, 2009 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Hi, I have a 2003 gmc sierra hd, duramax engine, 2 doors, long box. There is power locks on it and the door driver's door doesn't lock either with the driver switch or the passenger door switch, I change...
I have a similar problem. The remote sometimes opens all doors, and other times it will only open the 2 rear doors. Once inside the vehicle, the driver side window controls intermittently operates all windows and doors. It has no effect on the 2 rear doors, as the window controls still work. This behavior happens intermittently while driving the vehicle.
Aug 13, 2008 | 2002 GMC Envoy
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
118 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
