Question about Onkyo Audio Players & Recorders
Onkyo Tx-DS989 7.1-Channel/DB25 Adapter cable the colors are Green,White,Purple,Gray,Red,Brown,Cream, and Blue. What do the color connect to pertaining to speakers?
  • 21 Answers
SOURCE: Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Posted on Sep 03, 2007
pjszilard
  • 72 Answers
SOURCE: ONKYO tx-sr605 HDMI CHANNEL 2 INTERMITTENTLY SWITCHES TO STANDBY
Check the Ohm value (4, 8, 16...) on the speaker and on the ONKYO too.
If not the same that is the (big) problem!
Posted on Nov 24, 2007
freetek
  • 5568 Answers
SOURCE: No sound from Left and Right front speakers
You didn't state it but I assume the other channels are functional?
The auxilliary channels are generally lower power and may even be serviced by a different voltage than the main amps. If it is so designed, you may have something as simple as a blown fuse for the main amp supply.
If the aux. channels are equal in power, the power supply may still be dividing the load so a fuse still could be at fault. The unit could also use integrated power amplifiers in which case, if two channels are operating from a single module it could be a module failure.
I don't see much chance of anyone repairing this system without examining it in the first person.
Posted on Jan 08, 2009
freetek
  • 5568 Answers
SOURCE: Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
How do I reconnect using black & grey cables?
The colors of the cables are just so you can tell them apart. The standard color coding is RED is right audio channel and White is Left audio channel. Just make sure that whichever color (black/grey) you use the same color end is right channel on both or left channel on both.
Oct 11, 2015 | Onkyo Rc-251s Tx-sv303 Tx-sv313...
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Computers & Internet
I am installing a amp. Need to know what color is the remote wire. Is it blue white or some other color?
RED-12VOLT
YELLOW-MEMORY 12VOLT
WHITE-FRONT LEFT+/WHITE WITH STRIPE-
GRAY-FRONT RIGHT+/GRAY WITH STRIPE-
GREEN REAR LEFT+/GREEN WITH STRIPE-
PURPLE REAR RIGHT+/PURPLE WITH STRIPE-
BROWN-MUTE
ORANGE-ILLUMANATION
BLUE-REMOTE(AKA)AMP TURN ON
BLACK-GROUND(NEG.)
Jul 31, 2010 | Kenwood KDC-138 FM / AM Receiver
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Need a wiring diagram for a clarion db185mp
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Dec 27, 2008 | Clarion DB185MP Car CD/ MP3 Player
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
322 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
